Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a 1998 profile G.E. refrig that started making the clicking noise and the compressor shut off, I took the overload and the ptcr off and they rattled when I shooked them, I replaced them both plugged the ref. and started just fine for about 3 to 4 minutes, then it shut off and now not even the fan works, in which it did before. Model # TFX22PRBAWW. If I need to replace the mother board, please let me know where to find it. thanks!
My compressor read good, i can't find power to it. the condensor fan is running, but don't have power to compessor wires.???
Posted on Feb 14, 2015
  • GE Master
  • 2,605 Answers
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector again or the compressor itself is seized.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
If you have a multi-meter capable of voltage readings you can check see if the control is sending power to the compressor and subsequently to the condensor fan then on the continuity/ohm setting the compressor to see if the windings are ok.
**First, Unplug the fridge**
This part should be pretty easy since you've done this part before...Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor with the start relay/overload assembly such as this image...
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 startI have a 1998 profile G.E. refrig that started - 775ec2d.jpg />
i.e.
The above package contains info and hardware on how to connect it.
**NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" you should not rely on this for long term reliability or safety, but rather consider the compressor is on it way out unfortunately...but the hard start may by you some time.
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Posted on Dec 30, 2010
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Jan 16, 2008 | Refrigerators
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Making humming noise on and off and not cooling
Unplug the refrig and pull the refrig out and remove the lower panel covering the fan and compressor . On the compressor , is a small box ( overload/relay ) with 2 or 3 wires going to it . This part just plugs onto the side of the compressor . Take your complete model number with you so you get the correct part . If you had given the model number here , I could have given you the pt # . Also clean the coils in the front bottom of refrig , of dust , lint , pet hair , etc , as this could have caused the compressor to get hot and short the overload/relay .
Sep 27, 2010 | KitchenAid Refrigerators
Clicking noise coming from my fridge, why?
Depending on model number and location of noise I believe with any refrigerator that clicking will come from compressor overload when the compressor tries to start. Certain GE Models that fall into the category of Profile/Artica have motherboards that make the same clicking sounds when they go bad. If coming from compressor then it tells me that the compressor is trying to start. If so and the clicking continues the compressor could be damaged. If you need someone to assist you in repair I will gladly assist you. Sea Breeze
Mar 20, 2010 | GE Refrigerators
Kenmore 795 refrig is not cooling sounds like everything is running but no cooling. took back panel off and hear a click then a electrical sound which goes for under a minute then shuts off
That indicates that the compressor is overloading the wiring. That clicking noise is the thermal breaker. The freon could be low. causing the compressor to overheat, or the compressor itself is deffective.
Nov 25, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer not working
That is the compressor overload. I recommend you disconnect the refrigerator now to prevent damage to the compressor. It could be the start relay or the start capacitor is defective. Let me know when you are ready to test the compressor. This is serious that you disconnect asap to prevent damage to the internal overload. What you hear now is the external overload and the compressor will be too hot to touch. Sea Breeze
Jul 21, 2009 | Refrigerators
Refrig compressor only click but does not engage
Probably the start relay or a bad overload (check overload continuity with a volt/ohm meter) Maybe a broken or burnt off wire inside the compressor terminal cover. Possible, but unlikely compressor locked up. Unplug it before getting into the terminal cover.
Jun 27, 2009 | Magic Chef CTB1922 Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
