Question about Polaroid FDM-0700A 7 in. TV/DVD Combo
Backlight doesn't work
Where can I find the parts for this problem, and can I take the parts to a tv shop and have them put it in??
  • 3 Answers
Hey Nascar580, you can pick up an replacement substitute part from here:
http://www.lcdparts.net/InverterDetail.aspx?InverterNumber=UI8007S-1MSS
The original part UI8007S-1 is defective and the IC chip that powers the coil will contually burn out. The replacement was designed due to this flaw.
Posted on Sep 29, 2008
Sharp LC-40LE55OU flat screen. I have audio, no video. I can shine a flashlight on the screen and see images.
The backlight is not working.
Either part of the power supply board is not working or the backlight LEDs are not working.
Unfortunately, you'll have to take it to a TV repair shop. Get a quote on the possible repairs first. Check for reviews on the repair shop.
Don't open it up yourself, there are hazardous voltages even when the TV is unplugged!
Jul 19, 2016 | Sharp Televison & Video
How to fix backlights on Sharp 42
you lcd tv doesn"t be backlight problem. that"s be t -con board gone in. replace it picture should be back . good luck!
Sep 07, 2012 | Insignia IS-LCDTV32 32 in. Television
I hv got LCD TV hv No picture but have very good sound. While power put on ,it flash & go. What to do? This is for BenQ LCD TV 2680.Back light inverter is avllable? in case needed.
Hello
As you thinks mey correct to an extent. If backlight inverter board has some kind of short with its components, the fault you describes here will occur to LCD TVs, irrespective of Brand and Model. Most of the backlight inverters for any models are available at open electronic spare part shops at your town. Just take the backlight inverter board out from your Tv. It will have a special number printed on it, and should be noted when buying a new one. Remember its connections when you take the boaed out from your set. If needy, mark the positions of connecting wires to that borad on a piece of paper, for reference.
Replace the backlight inverter first. It must solve the problem of your BenQ LCD Tv. OK.
gopakumarg43
Oct 07, 2011 | Computers & Internet
Hello, we we have a 50 inch Samsung Plasma TV, from Bestbuy, went to bed and it was working fine, woke up and now we have audio, but NOTHING on screen, completely, black...also tried DVD and same thing,...
Tries tv unplung,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.Tv now 50/50 the tv might work as normal again.If the tv dosen't.Tv have a dead 1 or 2 backlight buffers boards have to be replacing.These 2 long backlight buffers boards only job are to provided a tv plasma screen panel for a backlight to see the picture.Tv now the plasma screen panel have no backlight that why ur tv have only audio sound and no picture.No experience in tv repair and never done any electronic board parts replacement before.Best just call many tv shops and explain the tv situation it in and get the best quote prices for parts and labors.Best prices parts and labors should be around $400 is fair more than that as i said shops around for more tv repair shops.
Aug 19, 2011 | Samsung HP-R5052 50 in. Plasma HDTV
My samsung tv's backlight doesn't work can i fix it
yes; you can replace the back light of your lcd, when you remove the back cover of your lcd you should remember all the parts that you will try to remove specially the screw, then you will see a rectangular pcb in the other side it has a small transformer this pcb is the inverter of the backlight of your tv try to follow the wires that is connected to this inverter and you will see the back light of your lcd, try to check the tube both end if there is black color then it indicates that the cathode tube is already damage.
Jul 17, 2011 | Samsung LA40R81BDX 40 in. LCD TV
Sound no picture. When turn on quick flash blue light then nothing. Product#RX326 model 3200 made July 2005 bought used
Backlight inverter is bad. You will need a direct replacement.
Search shop jimmy.com and encompass parts.
The backlight inverter is the part that allows for the illumination of the tv itself.
Thank you
Jul 07, 2011 | Proview Televison & Video
My tv screen wont turn on but the power light does and there's no sound can anyone help?
This is service center issue. It could be a part called the backlight or the backlight drive or the 'small signal board'. Any of these will require a shop.
Mar 29, 2010 | Philips 32MF231D Television
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
Sound with black picture,some reflection w/flashlight on screen
The problem is that your TV's backlight has gone out. Without this light, the display still works but you can't see anything. It may be that the backlight lamp has failed. But a more common cause is failure of parts called capacitors in the set's power supply.
I've never worked on a Polaroid, so I can't point you toward any specific parts numbers or values. You may be able to find more detailed information by searching for your specific model and "backlight repair". Capacitors are cylindrical parts that vary in size depending on their value. When bad, they often have tops that are bulging (should be flat) or have split open, and sometimes there may be discolored areas at their bottoms from leakage. Replacing bad ones with parts of the same capacitance value (marked on the part in mf or uf, as in 330uf) and a slightly higher voltage rating often fixes the problem. (Not always, because other things can go wrong.) Capacitors also have a polarity, so you need to make sure the new part goes in the right way.
A TV service shop could check the set if you can't find more information or don't want to try it yourself.
Apr 07, 2009 | Polaroid Televison & Video
Polaroid FDM-0700A 7 in. TV/DVD Combo Logo
124 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
