Question about Maytag MMV5000 Microwave Oven
HOOD LIGHT AND COOKING FAN NOT WORKING
I was replacing the two hood bulbs and as I screwed in the second one I heard a slight "pop". When I pushed the "light on" switch, neither light lit. Then, when I tried to use the unit, the microwave started but the fan that usually runs during cooking did not start and the turntable did not turn. The clock and everything else seem fine. I checked the fuse behind the keypad and it is a good fuse. Any suggestions?
Thanks, Russ
  • Anonymous Nov 18, 2008
    I hadthe same thing happen.
  • Maytag Master
  • 8,864 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 08, 2008
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Micro doesn't cook,vent or light, but timer works. Estate TMH14XM
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jun 10, 2009 | Estate TMH14XL Microwave Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Light failures
The bulb should be squeaky clean prior to installation. If any oils from the skin get on the bulb (or grease from cooking) that will shorten its life considerably. Always use the hood fan when cooking on the stovetop to prevent buildup of grease or moisture inside the microwave controls or cooktop lights. It might be that the door is being slammed while the bulbs are on - that can shorten their life, too. You might visit a home center (Home Depot or Lowe's, etc.) and see if they have any higher quality non-Chinese bulbs. Always be sure to disconnect power from the microwave completely before removing or installing the bulbs. Failure to do so can damage the control board. We repair a lot o control boards because of this type or failure.
Sep 16, 2007 | GE JVM1660 Microwave Oven
Maytag MMV5000 Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
