Question about Connecticut Electric FPE replacement 2 pole 70 amp full size
Dear Sir, I have a 240 VAC 60 amp Spa GFCI panel, I believe it is a 4 pole The part FH-20J-4 is not working unless the spring load breaker is manualy held down. Where can i purchase this specific part as i can not even find it on your websight and it is only a few years old. Todd
Today is july 15, 2011. i just came across this problem today. i have a connecticut electric spa disconnect panel and the part fh-20j-4 went bad too. it was about 3 years old. the spring loaded breaker would not retract automatically like it is supposed to do. i had been doing work in my home which required me to shut off the main power a few times. the last time i shut it off, my spa didn't come back on once power was restored. i didn't find out until later that evening when i wanted to get in my tub. i checked it out the next morning cause i've had problems with the panel resetting a few times before after a power ottage. this time it would only work if i held in the spring loaded breaker. i called connecticut electric at 1-1866-822-0453 and told them about the problem and gave them the part number. the person took my contact information and told me she would send me the part free of charge. try calling them. the number listed above is to their indiana office. hope this helps.
Posted on Jul 15, 2011
  • 1 more comment
  • julia Oct 03, 2011
    I have the same problem...it is really hard to find. If anyone knows of a replacement part with a different brand, I would appreciate it as it sounds like this may be a faulty part. Thanks for the information. I will call them!!!
  • Don Johnson Dec 25, 2012
    Same here, it's Christmas Eve, 25 degrees, and the FH-20J-4 contactor is faulty, which I discovered after pulling off the front spa panel and checking the fuses. I cannot find this part on line. Connecticut Electric does not list this part and their number has changed to 800-730-2557. I will call them after Christmas, hopefully I have no freezing pipe damage. Don
  • alistairA Dec 14, 2014
    Took mine apart. It was full of dead spiders. Beats me how they got in there.
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Why can't I use a gfci breaker my for sauna heater
26 Installing two pole GFI breaker
I'm not clear on why you can't use a GFI Breaker. Has someone said this to you, or have you tried using a GFI and it didn't work? Does the heater run off 120 v or 240 v?
May 31, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 18, 2013 | Pool & Spa
Need information on circuit breaker BR2100 60amp
Hi - I'm an electrician and can help you with your question.
A BR2100 circuit breaker is a 2 Pole 100 Amp (for the part number "BR2100", the "2" indicates the number of poles and the "100" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
A BR260 A BR2100 circuit breaker is a 2 Pole 60 Amp (the part number BR260, the "2" indicates the number of poles and the "60" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
It is not possible to have a BR2100 rated for 60 amps, 1 or 3 poles, or a BR260 rated for 100 amps, 1 or 3 poles.
It is not permissible to install any circuit breaker brand or type in any panel that does not specifically include it on a list of acceptable circuit breakers.
Circuit breakers are designed to carry 80% of the amperage rating.
To determine the load a circuit breaker can carry, multiply the circuit breaker amp rating by 80%.
This means that if you need to supply more than 80 amps, you cannot use a 100 amp circuit breaker. A higher rating is required. A BR2110 would be acceptable for loads greater than 80 amps, but less than 88 amps because the formula above says: 110 amp x 80% = 88 amps.
To determine the breaker size, determine the load (by measuring with a meter or obtaining amp rating of the load from the data plate) and multiply it by 125%. Using the same numbers in the example above; assume an 88 amp load. 88 amps x 125% = 110 amp circuit breaker. The 60 amp breaker is acceptable for up to 48 amps because 60amps x 80% = 48 amps. A 48 amp load needs a 60 amp breaker because 48 amps x 125% = 60 amps.
I hope this helps and good luck!
Jan 15, 2013 | Eaton Corporation BR2100 Circuit Breaker
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
I have a 200a main with 40 slots and the main breaker its gettin hot and trippin off i think its overloaded because i read 120a at one polo and 115a at other pole, and i place a fan at front the panel tn...
I don't know what may be wrong with your breaker ... I believe I would replace it or have it looked at by a professional. Your load is pretty well balanced ...
You certrainly don't want to have a prblem with it while you arent @ home.
Mar 23, 2011 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Hello i have a spa and i just installed a 60 amp gfci breaker and it keeps popping the breaker. idea
generally applliances, like refidgerators heaters, anything with motors don't like gfci's... or gfcis don't like them. take out the gfci breaker and you should be swirling in no time,... when's the party?
Dec 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Hooking up a Hot tub
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
Jun 22, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Connecticut Electric FPE replacement 2 pole 70 amp full size Logo
2,119 people viewed this question
Top Connecticut Electric Electrical Supplies Experts
Steve
Gene Haynes
Steve Pack
Steve Pack
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
