Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint first edition few12 wont fill
I've checked & cleaned the hose & the pump. Eventually found a filter in the black hose inside the machine - no blockage there. Lights come on as always so assume electrics are ok. Any other ideas please ?
    Scholar:
  • 97 Answers
Hiya
if your machine wont fill it will more than likely be a faulty inlet valve.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 03, 2008
Found the filter under the front kick plate.can turn it quarter turn Anticlock but it will not come out,Why?
I've got the same problem justnow. Read on another site that the reason that the filter wont come out is because of the amount of 'rubbish' that is behind it - best way is just wiggle it and hope that it eventually comes out (although sometimes this breaks it).
Good Luck!
Apr 25, 2011 | Hotpoint First Edition FEW12 Front Load...
My filter!!
First of all,lay the drain hose down to floor level and let the water run into a bucket or similar, this will empty the washer of water.
the filter is inside the large black hose on bottom of drum.
Undo hose, remove and clean filter
Refit filter and hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve your problem.
Good luck.
Jan 03, 2010 | Hotpoint First Edition FEW12 Front Load...
My machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
Jan 02, 2010 | Hotpoint First Edition FEW12 Front Load...
How do I locate the filter
To clean filter, remove lower rear panel of washer.
Remove large black hose onto bottom of drum
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Nov 29, 2009 | Hotpoint First Edition WMA12 Front Load...
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
How do I clean the filter on my Hotpoint First Edition FEW12? Do I have to take off the whole big black pipe at the back, under the drum? There is no filter at the fron
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Please rate my solution.
Thanks.
Nov 14, 2009 | Hotpoint First Edition FEW12 Front Load...
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Thanks.
Nov 06, 2009 | Hotpoint First Edition WMA22 Front Load...
Where is the filter on my hotpoint few12 can i clean it myself
Hi.
If you cannot find a filter at bottom right of washer, then remove lower rear cover, locate and remove large black hose on bottom of drum, you will find the filter in there.
Thanks.
Oct 21, 2009 | Hotpoint First Edition FEW12 Front Load...
Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
Aug 19, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wma12 not draining help please my work clothes are stuck
You need to check the pump filter which is accessed by removing lower rear panel of washer.
On the right you will see a large black hose, ondo securing clip and remove hose, be careful because there will still be water in it.
Better still , lay hose down into a bowl or similar to drain any remaining water in m/c.
Inside you will see the plastic filter, remove and clean, refit filter and hose, make sure you get it on properly
Test it for leaks, and that should be it.
If it still does not drain then you need to check the pump is o/k.
You can do this by listening or feeling if you can hear the pump going.
BE CAREFUL
Any more info , let me know.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
113 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
