Question about Delta 40 680 Electric Scroll Saws
I have an older Delta 40-640 Variable speed scroll saw. The motor is running erratic in all the speeds. Took the switch housing off and noticed a pc board, can I replace a particular part on it or do I need a whole new pc board.
SOURCE: grinder won't stay running
what is the mf(microfarad) rating and the voltage,then go to an industrial electical shopand buy one for the correct voltage and an (mf) equal or greater ,but not by more than 10%---mine cost $9.00-in Maine---good luck- MATT
Posted on Jan 04, 2009
  • 34 Answers
SOURCE: I need a manual for my Delta Scroll Saw 40-650
YOU'VE GOT THE MODEL NO. LOOK IT UP ON
THE INTERNET UNDER DELTA
Posted on Jul 01, 2009
SOURCE: I have a Delta 16
I PURCHASED THE MANUAL
Posted on Jan 02, 2010
SOURCE: I have aacquired an old
Hey fellow NZer, Yup, that's indeed possible, almost ANY motor can be speed controlled, if it's NOT too big, one can simply use a 100/150 Watt Light Dimmer, (the bigger the better) to do so, bigger motors will require a proper speed controller... PWM one...
One can get kits for speed controllers from Jaycar, or **** Smith too, Radio Spares if you have a dollar to spare, they seem to charge like wounded bulls, but their stuff is always available and always works.
I doubt if you would need a microcontroller, as the load is only 65Watts, as it's current draw is under an Amp.
I imagine that the Light Dimmer will suffice... Usually though you need to upgrade the heatsink on the Triac, in any event, by about double, just to be safe.
Posted on Aug 24, 2010
How to change a fuse on delta 20 inch variable speed scroll saw
there is a delta web site that gives you a down load manual if you don't already have one.
it shows you where the fuse is located on page 10 - fig. 10.
here is a link to the page
Jan 09, 2015 | Delta 40-690 20-in Variable Speed Scroll...
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
DW788 blows the fuse immediatly. I purchased it about a year ago and have finally gotten around to using it, so the warranty has expired. I took it apart and saw that a circuit trace below one of the...
can you bypass the motor speed controller(circuit board) and hook the line cord directly to the motor? then if it runs at full speed and doesn't over-heat ,you know its still good
Feb 11, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Saw has no power.
Does the motor continue to run, but the arm stops? It sounds like the set screw on the motor shaft is loose. See the exploded view at this link. It's called out as # 97 http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=5682&typeId=3475&documentId=333
Jan 13, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Saw blade broke. motor won't run after changing blade. reset wasn't tripped. lite still works so its not in the power cord.help! this is a craftsman 16 in. variable speed scroll saw not used very much....
It would have cost more to have Sears fix the saw than I paid for it, so I got my meter out and by checking the voltage drops across all of the electrical connections in the saw , I determined that the on / off switch was defective. This switch is the same switch used to turn the lite on and off, so I took the switch out of the lite and used it in the saw. I ordered a new switch for the lite and will install it when the new one comes. Thanks for your interest and help. fletcher1
Jul 17, 2009 | Craftsman 16" Variable Speed Scroll Saw
Changing control switch
Sorry, but that is not going to work ,that motor is not compatible with that type switch. you would need a variable speed motor.Newer models have many more improvements, you should try one of them,much smoother cut. Good luck and please don't forget to rate this answer.Thanks.
Mar 29, 2009 | Saws
Delta 40 680 Electric Scroll Saws Logo
270 people viewed this question
Top Delta Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Measuring Tool and Sensor Expert? Answer questions, earn points and help others
