Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
347002k can't get any operation from my machine,i was only able to drain the a/c on my car by doing a charge/vac command. what should i check first? it's a second hand machine that i just got and it's my first try on it.
    President:
  • 180 Answers
It's sound to me the problem with compressor! to make sure yourself please do the following. Press recover & fix a vacuum gauge on machin Compressor suction port(without connect to vehical) & monito the gauge is going to13"HG suction,if not then you need to replace the compressor. you can also check spin-on filter (press MENU button on the scree & then keep pressing up or down arrow key till appear "FILTER CAPACITY", then press ENTER key). if the filter already recover 68KG/150LBS refrigerant since last filter change. then you have to replace spin-on filter immediately! Over filter weight can cause the damage of compressor.
I wish this will help you to solve the the problem. if so, pls vote for it. Good luck!
Posted on Jan 07, 2011
347002k. wants to inject oil in charge mode? is it the check valve?
You have to do Just following # Check oil drain solenoid for any debris or damage inside the solenoid flunger. Replace/rebuild as needed. Hope this will solve your problem. Don't forget to vote for my solution
Nov 18, 2010 | Robinair Cool Tech 34700Z Recovery,...
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Sep 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
My washing machine will not empty of water and this is preventing it from spinning.how do i empty the water via pump filter as i have no manual and it will not let me download one.please help!
This is could be caused from several issues. First I would try changing cycles on the timer to another spin cycle to see if that let the washer drain. Some times the timer malfunctions and doesn't allow the washer to spin. If this doesn't work and you can hear the motor running then you could have a broken belt or bad clutch or a wig wag (electric solenoids that operate the transmission.). The easiest way to empty the washer if it's located near a floor drain is to remove the drain hose from the drain and lay it on the floor near the drain. The water will run right out of the machine. If you not near a drain then you can use a Wet / Dry Shop Vac, remove the paper filter from inside the Shop Vac and then your ready to vacuum out the water. You will need to empty the vac several times.
Or you can use a garden hose and siphon the water out by place in one end in the washer and the other end outside or near a drain, You will need to **** on the end of the hose that's near the drain or outside. This will almost guarantee you a mouth full of laundry water so be careful if you try this.
Aug 05, 2010 | Washing Machines
My machine says high pressure unit disabled and will not let me advance
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem
May 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
SC 302 servis call, command, How can I repair the machine? Pls reply,
SC302 is a charge roller leak. clean or replace charge roller to eliminate this problem. and give the machine a good vac to clean and remove the toner inside the machine.
May 25, 2010 | Ricoh Aficio MP1600SPF Copier
Am having problems with a 347002k, we have this recycler for some time and have replaced even the compressor. I think we need the digital control board with the input command (where you input the steps)....
You may did something wrong with your machine! Please try the following: 1# Switch ON the main power.2# Re-set (booth) circuit breaker (press booth breaker at the same time) & see if the screen is appear.3# If the screen is not appear after re-setting circuit breaker then you have to replace new control module.Hope this will help you.
Feb 18, 2010 | Robinair Cool Tech 34700Z Recovery,...
Reads high pressure unit dissabled
Feb 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
When unit is turned on a message appears that says "high pressure, unit disabled" how do you fix this problem? the machine doesn't let you do anything.
Aug 17, 2009 | Robinair Cool Tech 34700Z Recovery,...
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water filling tub when machine not in use.
slow pump out first you need a shop vac or a large mop for this operation lol if you have a shop vac turn it on wet pick up take the drain hose out of the drain pipe and open the door so you can hear then vacum all the water out of the washer you will hear when its done if you dont have a shop vac go to auto parts store and get radiator hose clamp remove bottom kick panel and if you did not vacum clamp the hose going to the tub from the drain pump will still get water but not as much still ya got to work fast then unscrew the front of the pump round piece with bar in the middle slide it out clean the screen then check to see if a forign object is blocking the impeller blades the mess is yours put the screen back and lock it down
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
218 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
