Question about Panasonic Televison & Video
Air filter need replacing and/or cleaning - Panasonic Televison & Video
  • mckeex5 Mar 16, 2009
    displays message: Air filter needs to be cleaned. Unit will turn off in one minute.. Display light on front of unit blinks five times in five seconds... No info given in manual to correct problem other than contact local service tech.
    Problem Solver:
  • 19 Answers
U need service tech. help. is really complcated for non experence people. good look.
Posted on May 27, 2010
How to clean air filter?
Hi Sharon!
If you have a paper air filter it will need to be replaced, rather than cleaned.
However if you have a foam air filter you can wash it in mild detergent and allow it to completely air dry and put it back into your chainsaw.
Here is a video about how to replace the air filter on a chainsaw, most are pretty similar, so if it's not quite the same brand as yours, it should give you the general idea.
Best of luck!
Replacing the Air Filter on RedMax Chainsaw
Chainsaw Air Filters I've also included a page to find replacement air filters for your chainsaw!
Sep 27, 2015 | Garden
Tip
Clean your air ducts and filter yourself
Cleaning your air ducts and replacing the filters can be small step that you can take to ensure that the air you are breathing is clean and to cut down on the electricity costs. While cleaning them yourself will not in any way come close to as thorough a clean as a professional cleaning. Taking an afternoon to clean your air ducts will make at least a small impact.
You will need a few tools to clean the air ducts that you probably have around the house, and if the filter is really dirty you will want to go to a home store and pick up a new one. You are going to need a vacuum, screwdriver, paper towels and a brush with stiff bristles.
Going room by room open the registers and and other air duct covers. With them open you should be able to reach a few feet into the ducts. Using the vacuum, vacuum up the dust and gunk in the ducts and if there is stuff that needs help getting out you can use the brush to loosen the stuck stuff. When the duct that you are working on is finished, close it up and move on to the next one.
You can continue this procedure for every register in the house and when you are finished it is time to get to the filter. Turn off the air conditioner locate the register in your house that covers the filter and get yourself a damp paper towel. Using the damp paper towel wipe the register clean if its dusty, and slowly open the register. If its on the ceiling you want to be careful that the filter doesn't fall on you. When its open remove the filter check the size and direction that the filter is sitting at (you need this for replacing it). Taking the new filter hold it with the air flow arrow facing the same direction as the old one. Close up the register and you should be good to go.
This method should help to reduce the dust particles in the air and will make your air conditioner a little more effecient. You should get a professional cleaning at least once a year to keep your air clean.
on Feb 12, 2014 | Hardware & Accessories
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
How do you clean all the air filters
Air filter's do not get clean, just replace, if filter not that dirty, you will need high pressure air to blow them out, do not wet the filter
Jul 02, 2010 | 2008 Toyota Prius
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Foam air filter needs replacing. It
I'm not sure what your question is, but you need to replace the air filter and in the future, don't clean the foam filter in gasoline. They will deteriorate with time, but gas will speed up that process. Wash it in dishwashing detergent next time.
Jul 13, 2009 | Homelite Garden
The screen is flashing E1
I was told the filter needs to be cleaned.
Turn the air conditioner OFF and unplug it.The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Hope this helps :)
Aug 07, 2008 | Danby Heating & Cooling
Leaking Air Conditioner
Try also to check if your evaporator fins is clean cause even if your air filter is clean will still present with dirty fins.
Feb 20, 2008 | Samsung AS18A6RB Air Conditioner
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Televison & Video Logo
456 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
