Question about NexxTech 175W Power Inverter
Nexxtech 2218175 fault light comes on and blew the power outlet fuse in the car. Can problem be fixed?
2012 Hyundai Sonata only one 12v power outlet working how to fix the other outlet?
Check the fuse in the instrument panel junction box, left side of dash panel. Tan color box, power outlet 1 or 2 15amp fuse.
Feb 01, 2015 | Hyundai Cars & Trucks
Lights don't work
test the following steps and fix it.use the VOM3eb53373-1eb1-4bb3-9641-1a202781b5bf.gif God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Jun 17, 2013 | Sharp R-1480 Microwave Oven
I pluged in a small car vac in the power outlet , after ten minutes it blew. Owners manual dosen't say there is a fuse for it.
There should be a cig lighter-accessory relay in the box near the battery. It is powered by a 9amp fuse and a 20amp fuse. The 20amp fuse is in the same box with the relay.
These fuses and relay power the front and rear outlets.
Dec 21, 2012 | 1999 Dodge Caravan
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
How to fix my 2006 stratus aux power outlet
I had a 2001 dodge stratus R/T. My mirror auto dim, digital compass and temp screen, and aux power outlet blew out because I had a power inverter plugged in and tried run something to required to much power. I was just a simple fuse. Go to the fuse box inside the car, not under the hood and check the small diagram on the cover and replace the required fuse. Good Luck.
Jun 17, 2011 | 2006 Dodge Stratus
Power does not come on after lightning strike
Check your wall outlets and see if you blew a breaker.(plug something else there and see if it powers that on) If not that I hope you only blew the fuse inside of the receiver. That would be an easy fix. Hope this helps!
Dec 03, 2010 | Yamaha HTR-5940 Receiver
2006 Toyota Tacoma, power outlet/cig lighter not working
I am not sure about "fusible link", But the suggeation I can give you is to open dash or where the outlet is located and check the wires in the back of outlet with a light tester.
Jun 03, 2009 | 2006 Toyota Tacoma
Power outlets wont work
when you look at the fuse box inside your car you will see a cigarette with smoke emitting from it for the cigarette lighter and the power outlet will have a button like picture on it.
Feb 22, 2009 | 1996 Jeep Grand Cherokee
NexxTech 175W Power Inverter Logo
82 people viewed this question
Top NexxTech Electronics - Others Experts
Are you a NexxTech Electronics - Other Expert? Answer questions, earn points and help others
