Question about Electric Eyeware Traxxas Velineon 3500 Brushless Electric Motor 3351
On my velineon ESC, there is a red light that is blinking and my Traxxas Rustler is not running more than 10% of its normal speed what is the problem??
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
The LED on the XL-5 is solid red after programming. The model operates normally, but the light is supposed to be green. What is wrong?
Press the ez-set button on the esc (the one with the heatsink) for ten seconds until it changes color and gives a beeptone,green is low voltage detection on for use with lipo batteries,if they are fully discharged they are dead,the detection system cuts power beyond 3v per cell so that the lipo isnt dameged
Dec 25, 2010 | Traxxas Rustler Vxl Rtr
How can you adjust a traxxas rustler for a novice driver so it doesn't go so fast?
When turning on, press and hold the button on the ESC until it flashes 1, 2, 3 times then let go of the button. You are now in novice mode.
Dec 24, 2010 | Traxxas Stampede and Rustler Vxl
Vxl-3s velineon problem with speed control
This problem is very common with the traxxas vxl 3-s speed control. If you were previously running it in 70 degrees or above without a cooling fan, hobbytown is correct. If you have a fan, or it is cool outside, try your best to return the speed control for a new one.
Jun 21, 2010 | Traxxas Toys
I need to rebuild the inside of a traxxas xl-1 esc i need the bord layout and wireing
You can send it back to Traxxas and they will repair it for $15 plus $5 shipping/handling if there is no signs of abuse. A new xl-1 esc is $60 from Traxxas.
May 19, 2010 | Traxxas Rustler Stadium Truck
Electric Eyeware Traxxas Velineon 3500 Brushless Electric Motor 3351 Logo
388 people viewed this question
Top Electric Eyeware Toys Experts
ray gallant
Are you an Electric Eyeware Toy Expert? Answer questions, earn points and help others
