Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Timer light blinking and fan within tv running. TV will not turn on. Timer light continues to blink, what do I do to turn it on?
  • 312 Answers
I don't know if this is the situation with your TV or not. But that set can be locked up in such manner as it cannot be turned on using the parental control features. Below is a link to the operator's manual. I looked at Appendix A which gives instructions for bypassing the lock system on your remote control and on the front controls of the set. It is on page 83. It's very interesting.
I hope this helps you.
Good Luck
Mark
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Dec 30, 2010
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Dec 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
