Question about Whirlpool Washing Machines
Please help my washing machine is diplaying a fault the code is f du what does this mean? i cant open the door and i have tried turning the power off..
    Novelist:
  • 99 Answers
Fdu code is saying there's a door unlock problem. There is a manual release for the lock. Remove the front panel under the door (3 screws at bottom of machine) reach in by the lock and there will be a plastic tab hanging down, if you pull that down the door should open. When you have the front panel off, taped on the inside of the machine should be a large packet. This packet has the technicians troubleshooting guide and an explanation of all the codes. Good Luck.
Posted on Dec 31, 2010
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
Hi. My washer is coding dU then F as codes.. I cant get it to shut off and unlock the door to get cloths out. The book does not have a code for dU.. PLEASE SOMEBODY HELP ME :)
Door unlock error. The machine tried 6 times to unlock the door. Must be an item of clothing jamming the door. take the bottom panel off and reach up and grab the emergency ring, GENTLY release the door amigo. Use this GUIDE for repairs
and use your tech sheet inside that base panel for error codes and diagnostics.
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have od on my control panel what does it mean
The OD "fault" code on the display means "OPENED DOOR". This does not mean the machine thinks the door is open, but it has not recognised that the door was opened prior to starting a wash cycle. This could be because you filled it, then turned it off before turning it back on to run the cycle. Often you can clear this "code" by simply opening and closing the door again and starting the wash cycle as normal. If this doesn't work then there may be a fault in the door lock switch or the control board.
Hope this helps.
Regards,
BElectric
Dec 01, 2010 | Maytag Washing Machines
Error code and machine not washing
Some washer and dryers will clear the codes by unplugging the machine from the wall.... Leave it unplugged for 30 secs... then plug it back in..... may clear code..... and may unlock door so you can get the clothes out.
Unsure of the code meaning.... but if you clear it by power down and it works don't worry about it unless it returns quickly.....
Jul 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
LG Driect drive what does DU mean on the washing machine
Are you sure the error is DU?
That DU is fault of the main board and it will need to be replaced.
Apr 10, 2010 | LG WM-2277HW Front Load Washer
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
My kenmore elite smartwash/he4t (error code)
Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
Apr 04, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
