Question about Kenmore Washing Machines
My Kenmore 700 Series washing machine started leaking. When the problem was diagnosed the washing machine basket had slid down the drive shaft to where the basket was rubbing against the bottom of the tub. This caused it to wear a groove in the bottom and started leaking. The basket drive block was 2 3/4 in and the drive shaft was 3 1/2 inch which left a 3/4 inch gap for the drive block to slide down. When it slid down the cleats at the bottom of the basket drum wore a groove in the plastic tub. Have you heard of this happening before with this unit. Sears claims that they only have a bulletin for the replacement of the tub gasket and a sleeve (TB26-80) for water leaks. What would you recommend that I do. They are sending a tech out next week at a cost to me, but I think that this is a design flaw or a miss used part (basket drive block).
danromarris
  • 101 Answers
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
mgprice
  • 744 Answers
SOURCE: My Kenmore 80 series topload machine is leaking water
This machine has a direct drive pump, in all likelyhood the pump is leaking...unplug machine...pull it out...tip machine on its back so you can access the bottom, if it is the pump there should be water around where the pump connects to the motor, if it is the pump it is a simple process of releasing 2 clips and taking the inlet and outlet pipes off the pump..install new pump the way you took old one off. you can obtain the part from www.repairclinic.com If you would like to give me more details on your dryer i may be able to work out what is wrong with it.
Posted on Jun 23, 2009
  • 3230 Answers
SOURCE: I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Posted on Jul 07, 2009
  • 1937 Answers
SOURCE: Kenmore washing machine is leaking water from the bottom left fro
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on Jan 24, 2010
  • 1937 Answers
SOURCE: Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Posted on Jan 26, 2010
I have a Kenmore Series 700 Top load washing machine. I am trying to remove the spin basket, but can't get the 7/16 nut off to remove the agitator. I have tried clockwise and counter.Any suggestions?
If you're using a ratchet to remove the bolt you'll typically need to use a hammer on the end of the ratchet to shock the bolt loose. Just using torque the basket will try to spin, ideally an impact driver would be best.
Dec 01, 2017 | Kenmore Washing Machines
Kenmore oasis he washer 110.27062602,sd codes,and stripped put hub gears
Check the basket the very bottom ring is the float and some how leak and do not float well enough to disengage the basket when agitating and strips the hub.
Jan 12, 2012 | Kenmore Oasis HE 27062 Top Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 series top load washer. Will work on
if that arm is white and inside your clutch assy,that is the brake release arm that releases the brake to allow the basket to spin. it has 2 little fingers on it that lineup on the brake release cam, also check the bottom of yuor basket drive tube see if it has worn down or if the clip is there that holds that arm in place
Feb 21, 2010 | Kenmore Washing Machines
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Sears 700 series top load washer, model 110.27711600
no that is a shipping pin when they pulled the strap those pins fall into those little cups instead of onto the floor. so it does not spin. does it agetate? if the answer is yes you probaly have a good drive coupler. Possible suspects would be a bad transmission if it is stuck in nuetral drain, clutch if you can push start the basket in spin cycle you have a bad clutch, bad drive block you need to take the agetator off and check to see if the drive block is not raised from the basket drive basket drive has 2 ears that fit into the drive block.
Jul 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 700 series washing machine
check to see on the top of the basket if there is a balance ring it will look like a large doughnut if it has one and if it is loose or if the fluid in the ring has leaked out then this will cause the out of balance while in spin let me know if i can help 276 523 4434
Apr 25, 2008 | Washing Machines
Washing Machines Logo
119 people viewed this question
Sal De
fordexpert
Robert Rankin
