Question about Creda C362E Electric Kitchen Range
Creda EDO 202
We've had our Creda 202 Double oven for 13 years and the oven still works fine but the electric panel and lights do not operate, i.e., timers, sensors, rotisserie, etc. Went out after a power failure last year. Can one replace the main panel with the motherboard?
2 Suggested Answers
  • 1462 Answers
SOURCE: old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Posted on Jun 22, 2008
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
How do I turn the timer off on my old Creda Hallmark oven?
I recommend replacing the entire unit. 20 years is well past the operational life cycle of the oven. You deserve a new unit for sticking with it for so long. Besides, the new ones are more energy efficient.
Jul 28, 2014 | Creda Kitchen Ranges
I have a double electric creda oven and i have just had the house re wired. becasue the power has been off the oven is flashing on the display at 0:00 auto and i cannot switch my main oven on as when i...
While holding minute minder and cook period buttons press + or - to set the time after time is set release buttons this should allow for normal operation
May 27, 2014 | Creda Ovens
My Creda convection oven does not heat up. The
THIS SOUNDS LIKE THE ELEMENTS HAVE BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE PANEL INSIDE THE OVEN REMOVE ALL SCREWS AND PANEL THEN REMOVE THE ELEMENT FROM ITS PLUG CONNECTION TAKE THE ELEMENT TO A ELECTRIC AND PLUMMERS SUPPLY STORE REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 20, 2009 | Ovens
Creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Feb 21, 2009 | Creda C362E Electric Kitchen Range
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Old Creda double oven keeps runing when switch off
Jun 22, 2008 | Creda C362E Electric Kitchen Range
Need light bulb for oven model #48113(EDO 202) white. Please advise where I can order
it is a standard bulb - usually small edison screw but make sure one you buy is heatproof type. available any elec shop (in uk anyway)
Jun 20, 2008 | Creda Kitchen Ranges
Creda C362E Electric Kitchen Range Logo
64 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
