Question about Frigidaire Dishwashers
I Have a Frigidaire dishwasher. FDB1100RHC2. It is only a couple of months old and it is not draining properly. I cleaned everything and dismantled the 2 hoses underneath. There appeared to be no clogs, but it still won't drain.
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Posted on Apr 27, 2009
  • 10865 Answers
SOURCE: Jenn Air Dishwasher won't drain out water. I have checked basket and hose for clog
The problem is most likely that there is a chunk of glass or bone etc. in the small drain pump. this is an easy fix. remove the lower front panel of the dishwasher, you will see the drain line which goes through the cabinet wall into the sink drain and at the lower end is attached to a small pump. Disconnect the hose clamp and the hose by the pump then unscrew the little pump from the frame of the dishwasher so u can look in it. Remove the blockage. Now reassemble everything and u will be back up and running
Posted on Apr 28, 2009
  • 109 Answers
SOURCE: i have an americana/ge dishwasher. it will not
check for food in the drain inside the dishwasher it can clog up and is very common
Posted on Jun 30, 2009
  • 132 Answers
SOURCE: Ariston L 63 dishwasher does not drain.
DONOT EVEN TO TRY TO DEAL WITH SALT CONTAINER , YOUR PROBLEM IS OUT OF THIS AREA,
YOUR M/C MAY NEED TO DEAL WITH DRAIN PUMP
IT IS ALSO UNDERNEATH>
THANKS
Posted on Jul 06, 2009
I have a AEG 50870 Favorit dishwasher, it is not letting water in, although when I manually put water in, it drains properly
Hello.
Had same problem on my AEG F55204 dishwasher.
Problem solved very easily. cleaned pressure chamber only.
see attached pictures
clened aeg pressure chamber-gpfsjtvpk02j51hgnqm10fvj-4-2.pngHope it will help to you as well.
FYG no need to dismantle everything. just take off fwrd cover to check chamber and then use some small wire to clean it from inside.
Oct 09, 2017 | AEG Dishwashers
My gallery dishwasher doesnt drain all the way
Thank you for your inquiry, friend!
From my understanding your Frigidaire dishwasher doesn't drain properly. It could be possible that your drain line or filter trap is clogged. I would recommend checking the drain hose to make sure it is not clogged or kinked. You can also look at the filter in the bottom of your tub to access that filter you would need to remove the rack and it is located right under the spray arm. You should be able to lift up and pull the trap out if it is dirty clean it and reinstall it. If everything appears to work properly it could be a possible issue with your drain pump and you may need to have it replaced. I hope this information is helpful for you. -Matt
Feb 27, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Frigidaire dishwasher FDB20RHS3B is not draining water. I have cleaned the water out of the bottom, cleaned the screen and parts in the bottom. Took drain hose off from garbage disposal (which is...
Hi Monique,
By any chance is your kitchen sink draining slowly? If the main drain is clogged it will back-up all the way to the dishwasher. Try using 2-Second Plumber or a similar product with a CO2 blast to clean the whole drain first.
Oct 22, 2013 | Frigidaire Dishwashers
Frigidaire dishwasher (FDB1100RHC2) is leaking from bottom right corner and it appears there are small hairline cracks on the plastic tub. Is there a way to repair them?
Hello - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, from what you have described it sounds like the springs or hinges may possibly be damaged, or gasket not sealing properly. I would strongly suggest contacting a professional to move forward accurately.
Oct 12, 2012 | Electrolux Frigidaire Professional Series...
I have a 8 month old Frigidaire Professional dishwasher which will not drain. What do I need todo? Email: cujobuddy12@yahoo.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Frigidaire Dishwashers
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
After installation my new dishwasher is leaking around the door. My dishwasher is a FDB1100RHC2 TH94532456
Improper installation - either the legs are not leveled properly, the tub is "twisted"by tension made by wrong screw placement on the top, or the door is rubbing the top or one of the sides. The worst case scenario would be a damaged dishwasher frame, but it's rare.
Dec 17, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Drain pump
My husband did remove ours,and we too have a frigidaire 18" built in dishwasher. But ours won't drain, he says it might
be the pump, but he is hoping not.. everything works except when its draining. water just sits there in the bottom.. He took it apart and cleaned everything, but still the same issue.. Any suggestions for me will help also.. TY< PAMMIE
Dec 17, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
238 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
