Question about Reddy RLP55V Utility Heater
WON'T RUN WHEN YOU RELEASE THE HAT START - Reddy RLP55V Utility Heater
  • 1,476 Answers
Virdic,
More than likely you have a problem with the thermocouple. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, where to get the parts and how to fix the unit.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
Engine won't run
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine cranks but won start Troubleshooting tips
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
Troubleshooting and Fixing Car that Won Start
No Start Diagnostic Basics EricTheCarGuy
Mar 22, 2016 | Cars & Trucks
Chevy van
Smoking issues after warm start up are usually caused by brittle valve stem seals and oil leaks down through the valve guide. These can be changed on the engine without head removal. Just use a air compressor to keep the cylinder full of air with the valves closed then remove the rocker arms counting the number of turns to keep adjustment. With a on car spring compressor remove spring. The valve keepers can be tight in retainer so tapping the retainer with released tension they will break free. Most chevy heads have 2 oil seals a hat type (positive spring seal) and a o-ring seal. With spring removed take both seals off there are very brittle. Replace the hat seal first then install spring with retainer. the o-ring seal needs to stay in retainer and in lower groove then install valve keepers and slowly release the spring pressure, Once spring compressor is removed then tap valve stem with hammer to seat keepers then release air. Also check Intake manifold bolts for proper torque. A loose manifold will also **** in oil bolt torque is 35-40 ft. lbs cast iron 30-35 ft. lbs aluminum manifold.
Nov 05, 2013 | 1992 Chevrolet G20
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Nov 28, 2012 | HP Compaq ProLiant DL580 G4 (430811001)...
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
My dryer won't stay on - if I release the start button it stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Dryers
Does linux support intel(r)82567lm-3 gigabit network connection, is driver available
Most of the drivers are supported in the latest fedora versions.Red hat is a standard release versions so some drivers were not available in that case you can update the kernel.So you will get most of drivers.
May 05, 2010 | Red Hat Enterprise Linux ES 3 Standard...
Engine cranks but doesn't start
Pull off the hat and lay it up on the wipers. Run plug wires from the coil adapter towers to the plugs. Run a ground wire to ground the hat. Check for spark with a spark tester one wire at a time. Don't get near it when you have a friend crank it, there is enough voltage in the ignition system of a 2.3 quad 4 to kill you. I'm not kidding, just be careful.
Mar 01, 2009 | 1994 Pontiac Grand Am
Reddy RLP55V Utility Heater Logo
60 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
