Question about Minka (RC588TW) Remote Control
LIGHT BUTTON BROKEN
THE LIGHT BUTTON DOES NOT WORK ON THE REMOTE. ALL OTHER BUTTONS WORK. HOW CAN I FIX THE LIGHT BUTTON, OR GET A NEW REMOTE? THE NUMBER ON THE BAK OF THE REMOTE IS CHQ8BT7053T.
  • scottva Aug 29, 2008
    I have the exact same problem.
    dkmarchuck - did you ever get this resolved? Or if you purchased a replacement, what model was compatible? Thanks!
I had the same problem with two remotes. Replacements are either hard to find or very expensive, so with nothing to lose I opened it up. There's a circuit board inside, and the rubber buttons are all connected together in one grid or mat. Each button has a corresponding copper square on the circuit board. I immediately saw that the square for the light dimmer button had a dark smudge, presumably from the rubber button.
The smudge was easily cleaned with a q-tip and denatured alcohol. Put it back together, and the button works!
Note, there are two screws that hold the remote housing together, but just one was visible on my unit. The other is below the sticker (with the FCC info). I was able to access the screw by simply pressing the screwdriver through the sticker.
Posted on Nov 01, 2008
I had the same problem. open the remote (two screws) one under the label. I used a pencil eraser to clean contact on left side of computer board. Then took the buttons out and spun them around. screwed it back together and it works fine.
Posted on Oct 27, 2010
Remote shows white light but not working
Point the front of the remote into a camera lense then press a button on the remote and if no lights show when u look at the camera while pointing and pressing a button on the remote its either broken or lost programming for the tv
May 05, 2014 | Televison & Video
My remote control does not work suddenly
Try installing new batteries such as Duracell batteries. Make sure they are installed properly in the remote with positive to positive nodes and negative to negative node. If you own a digital camera, you can test the remote to see if it is working. Point remote at camera (powered on) and press a button on the remote. If you see a blue / purple light on the remote's led, then the remote is working. If not, then the remote is probably broken and you need to buy a new one.
Aug 09, 2010 | Sony RM-PP404 Remote Control
Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Aug 19, 2009 | Universal Remote Control Dish Network...
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Only VCR button lights when I hit power
OKAY IF YOU NEED ASSISTANCE PROGRAMMING THE NEW REMOTE TO THE TV OR RECEIVER LET ME KNOW. THANKS FOR USING FIX YA AND FOR ALL CAPS.
Apr 19, 2009 | DISH Network IR Remote Control
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Nov 16, 2008 | Samsung AA5900213A Remote Control
Minka (RC588TW) Remote Control Logo
1,176 people viewed this question
Top Minka Televison & Video Experts
Electro Med Services...
Are you a Minka Televison and Video Expert? Answer questions, earn points and help others
