Question about Goodman GMS807034ANA Heater
No heat, but the fan are working - Goodman GMS807034ANA Heater
  • 1,772 Answers
Sorry to read about your heater problem.
Chances are you have a defective glow rod, this is the electronic pilot lite for the system, i would guess its not lighting the gas for heat
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Have a nutone 765hl-a heater blows but no heat
If the temperature control is turned up for heat but it is not heating, it is most likely a bad heating element or temperature control. Most heaters are not repairable.
Feb 19, 2015 | Dryers
Zafira radiator fan
Turning on the heat removes heat from the engine as it blows it on you. Make sure first that there are no air pockets in your cooling system as that can cause high temp reading and malfunctions in proper fan engagement. If that looks good test your fan, if it is working then test the fan relay, if it is working test the temperature sensor that gives the relay the go ahead to engage the fan.
Jan 16, 2014 | Cars & Trucks
My laptop is over heated now days and cooling fan also not working properly so what should i do ?
Hi, First blow out your fan and heat sink. Dust and lint may be causing your over heating issue. If you mean the fan is not working properly, due to it over heating this problem will also be resolved. If the fan is not working properly I.E. making noise, not spinning etc...Then the fan should be replaced.
Robert
Oct 20, 2013 | Computers & Internet
Double fan assisted oven, the fan is not working and no heat at all. Im assuming you dont get any heat at all if the fan is faulty? Can any one suggest any ideas?
Typically, the coils heat and the fan moves air/heat throughout the oven like Emergency Heat in a home furnace: 1st. check thermometer connections, 2. Look for reset button and reset...also, your electrical outlet, 3. make sure your coils are heating and if so look for faulty relays on your fan connections.
Feb 05, 2012 | Ovens
When heater is on the fan turns off. when we switch the fan on the heat element turns off but fan comes on. one or the other works but not both at the same time.
In some unit heat mode will start the fan after few seconds. Wait for max 3 minutes. If you turn it to fan mode, fan will only work no cool or heat will respond.
Dec 26, 2010 | Heating & Cooling
Soon as i turn on my heat my cooling fans come on first
It sounds like you do need a thermostat with your heat shut off and the gauge will raise a little then the car doesn't have that heat drawn from it indicating that you most likely do need a thermostat. As far as the fans coming on immediatly that could be a different problem it is most likely the coolant temperature sensor that tells the fan's when to come on. If this sensor says the coolant is hot the fans will come on immediatly. These are seperate problems as the coolant temperature sensor does not have anything to do with the cabin heating system. You should first check the level of your coolant is full, This could also cause your cabin heating system to perform poorly, and may have adverse effects to the engine cooling system. (fans)
Dec 31, 2009 | 1995 Nissan Maxima
Heating & Cooling Logo
42 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
