Question about Magic Chef Kitchen Ranges
My oven doesn't heat up past 75 degrees and you can smell gas -- it was working if I turned it off and then back on it would begin to heat up correctly but now that doesn't seem to work anymore Is this something that can be easily fixed?
  • wisdomdawnam Dec 29, 2010
    Thanks Daniel
    couple of questions -- what do I need to check the oven temp. sensor for 1100 ohms? Also, I'm no certain how I would check the control and door switch... and I was wondering how come you are saying it may be this even though I had not opened the oven door at all
  • 4,323 Answers
Hi
The issue can either be a bad door switch/lock assembly or the oven temperature sensor (probe) itself that has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 29, 2010
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    Hi
    I would suggest you to turn off the gas supply to the oven, and unplug it from power outlet. Now, use a multimeter and check the oven temperature sensor for 1100 ohms. Since you are saying that the oven does ignite and heat up, it could be due to the internal gas valve. The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. That is the reason why you could smell gas leak, it was allowing too much gas. Don't use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself. Call your gas company if you could smell gas leak even after turning off the supply to oven. Hope this helps... Please post back with model# if you need more information or if you are qualified to continue with this repair.
    Daniel
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven ingniter lights , smell gas but oven doesnt turn on
Hello- Ignitors may 'light' yet not reach proper resistance and temperature, causing improper gas flow past valve. If resistance is below 4 ohms, ignitor is bad. Part is 40-75$ at local app. parts store. Fairly easy to replace. Hope this helps. -Thanks- ED
Mar 01, 2010 | Kenmore 71513 Gas Kitchen Range
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
Gas Oven doesn't work under 450 degrees
most common issue is a bad bake ignitor, easy fix, probalby about $75, located on the side of the bake burner, simple to replace a few screws and 2 wires
Nov 17, 2008 | GE JGRP17 Gas Single Oven
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Ge gas oven with electronic ignition
yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Feb 28, 2008 | Kitchen Ranges
Oven works when it feels like it.
The ignitor is weak and not lighting the oven consistently. Need to replace the ignitor.
Nov 16, 2007 | Amana RanARG7302 Gas Kitchen Range
Oven Burner turns off during preheat
Mike, I think your problem is in the ignitor itself. Turn the gas off and see how many amps it's drawing during the bake mode. It needs between 3.2 and 3.6 amps to keep that valve open. Then ohm out the temperature probe, appox 1132ohms at room temp. You can see if your electronic control will go into a quick test by pressing and holding the cancel and broil buttons together for 3 seconds. First kill the power to the range and power back up before entering. When quick test appears you can check the bake relay by pressing bake. The relay should activate and 1 should be displayed. Same thing for convection bake except the fan should run too. Catriver...post back.
Feb 24, 2007 | Jenn-Air JGS8850BDS Stainless steel Gas...
Kitchen Ranges Logo
54 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
