One speaker/earphone doesn't work on my pc
I have a custom built PC, but only one speaker or earphone works when you plug them in. I've tried different speakers/headphones but it still only comes through one side. I've check all of the sound/balance settings and they are all set so the sound should be equal. Can you help?
    President:
  • 1,314 Answers
Are you plugging them into the back? If so, check the audio headers on your motherboard. They'll look something like this:
o o
o o <--- Make sure there is a jumper here
o o
o o <--- And make sure there is a jumper here
o
Posted on Jul 07, 2008
How can I plug earphones into this - which plug do you use?
Unless it has a plug for earphones it will not be an easy task. Most tvs only have line out (no volume control) or speaker out (rare) to plug in external speakers. Speaker outputs would be much to high to try earphones with. Line out will probably work but with no volume control unless you have it built into your earphones. You will also need an adapter to use the earphones with the line out.
Sep 09, 2015 | Televison & Video
Built in speakers not working
My built in speakers are not working on my macbook. The earphones work fine. I have tried checking in Sys Preferences Sound Output - but there is only the Headphones option available.
Jan 08, 2014 | Acer TravelMate Computers & Internet
Speakers work when earphones plugged in
Hi there must be something wrong with the outlet plug.
You can start this process by disconnecting ,the speakers and earphones from the device and the TV from the power supply for 2-4 minutes then start again .. If this does not work this way I might have to look at earphone
good look
kolbrun..
Jun 07, 2012 | Samsung N150 Netbook
I am not getting any sound from the spekers, however I am getting sound through the earphone
Plugging-in the earphones physically DISABLES the built-in speakers. Unplug the earphone, to ACTIVATE the built-in speakers. Hopefully, the action of unplugging will move the MECHANICAL contacts -- if that mechanism is broken,
then it's like trying a broken light-switch -- you can flip the switch,
but nothing happens.
Oct 07, 2010 | Dell Latitude D810 Notebook
PC Speakers will not work
This may be due to the plug on the computer. when the earphone is plugged it moves a piece of metal that connects to the shank of the earphone plug. When the plug is removed it shoukld spring back and reconnect the internl speakers. if this does not happen due to loss of springiness the speakers will remain mute
ple4ase rate our help to keep the service online
Aug 19, 2009 | Computers & Internet
Built in Cam & Audio Problem
with help of your motherboard book let select the right (correct mdel) for the both camera and sound card. the prblem will disapper. only driver problem
Apr 19, 2009 | Computers & Internet
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
-mate JAM Pocket PC Problem
Try putting in earphones and check. Sometimes the contact inside the earphone jack jams against each other and then the phone thinks there are earphones plugged in thus bypassing the speaker.
Oct 27, 2007 | i-mate JAM Pocket PC
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
