Question about Bosch Vacuums
I have a Bosch 1450W - Bagless Jet 12Amp - it will not turn on and the filter has been cleaned. it smelled like it over heated the last time we used it. Ellen
4 Suggested Answers
SOURCE: Bosch BUC11700UC Cyclone Jet Upright Bagless Vaccum
I had the same problem. I ordered a new switch from a local appliance place part#417915 (also try 54542), but it can be found on-line for ~$2+shipping. There are 11 screws to remove. Remove all nine screws that hold on the back of the handle (be sure and get the two under the attachment holder). Remove the two screw from the front that hold the top dirt canister retaining bracket. Once you have the back of the handle off, you can remove the single screw at the top of the handle that holds on the top front where the switch is. The front will then 'snap' off.
The wires are soldered to the switch, and there is absolutely no slack in the wires, so I don't recommend that you cut them. Be very careful with the new switch, since the tabs on back can break off very easily if bent too much (speaking from experience). You might also want to order, and keep and extra switch, around for the next time you need to replace it (it will wear out again).
Instead of soldering the wires to the switch you might want to try using some push on female spade connectors (small), but be sure they are insulated. This will make the next replacement much easier.
Posted on Feb 04, 2009
galati2k
  • 281 Answers
SOURCE: i cant get the power brush to work
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Posted on Apr 08, 2009
  • 75 Answers
SOURCE: My Bosch 1450 Bagless Jet vacuum cleaner shuts off
maybe or it could possibly an eletrical problem.
Posted on Jun 29, 2009
Filter mesh holder is damaged, locking holes are broken will not lock in place - need new filter mesh
Hi Joe: The model has been discontinued and difficult to find replacement parts. I located a few online suppliers offering a HEPA Filter that fits the BUC11700UC. See here:
http://www.vacuumcleaners.net/bosch-buz200hcuc-hepa-filter-for-bagless-jet-upright.html or
http://www.allergybegone.com/boshepfilfor4.html or
http://www.wikio.com/product/vacuum-parts-accessories-compatible_with_bosch-reviews-12020-page3-sort0.html
Is this the part you are looking for? The third site above does offer other replacement parts if you are looking for a different filter piece.
Thank you for using Fixya!
Jan 14, 2012 | Bosch BUC11700UC Cyclone Jet Bagless...
Smelly Animal Bagless Dyson
You've cleaned up urine...somehow. To remove that odor, go to a local flea mkt or store that sells essential oils and buy "Citronella" (smells awesome) 1/2-1oz. bottle will last forever. Add 4-5 drops to the paper filter element - smell gone!
Good Luck
Jun 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Dog smell after cleaning
This is an inherent problem with bagless vacuums. The filter(s) will absorb odors and odors will get trapped in places that you cannot clean. This is why I always recommend bagged units. They are easier to clean and the odors go out with the bag. About the only thing you can do is put a deodorizer in the machine and keep the filter clean. Be careful not to use petroleum based deodorizers as they can affect the plastic.
Feb 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
113 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
