Question about Epson Perfection 1250 Flatbed Scanner
I cannot get the epson scan software to work on my workforce 633. I have tried everything! Unistalled then reinstalled. tried both on usb and with network. Scan function is not workinng from the unit or the computer. I can only scan to memory card and that is it. When I test the settings on the scanner it shows on the computer as working fine and reads it and all but when I got to scan from the LCD screen on the printer it reads that it cannot communicate with the comoputer??
5 Suggested Answers
SOURCE: Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Posted on Mar 06, 2008
sherlyn c
  • 134 Answers
SOURCE: epson stylus cx7800 scanner distorted line running top to bottom
The drivers that are compatible with windows 2000 works with win xp too.
If you want to get the epson scanner driver for the cx7800 that is compatible with win xp, please log on to click on all in ones to the left of the page. Then click on flatbed under all in ones. Click on Epson Stylus cx7800 under 2.Then select your product to the right of the page. Click on Windows under drivers and downloads. Click on the 8th driver down which is the epson11577.exe, it says TWAIN Driver and EPSON Scan Utility v2.73A, then click on download now. click on thanks i prefer not to receive this information then click on the accept button. Click on direct link to the file then run the driver.
NOTE: make sure that the scanner is off and unplugged from your computer while you're downloading the drivers.
Do not forget to uninstall the drivers too before you install the new driver.
To uninstall driver:
- Click on start.
- go to control panel
- go to add or remove programs
- highlight epson scan then click on change remove and just go ahead and remove the driver.
- then restart your computer.
- download the driver once your computer is fully booted up.
Posted on May 13, 2009
  • 2785 Answers
SOURCE: My Epson Workforce 500 all in one will not scan
plz try by reinstalling the drivers and scan your system for viruses
Posted on Nov 06, 2009
  • 3278 Answers
SOURCE: When I try to scan
There could be a problem with your computer's USB port or the scanner's USB cable. Are you plugged directly into the computer or into a USB hub? Did you try a different USB cable and a different port on the computer? Can you try the same printer on another computer?
Hope these suggestions help.
Posted on Aug 10, 2011
My Epson DS-6500 suddenly stopped working and my POS HP PC is giving me some NVIDIA driver issue.... H
  1. Epson Support - Drivers, FAQs, Troubleshooting, Technical ... EpsonWelcome to Epson Support for the U.S. ... Epson WorkForce® Series ... Epson DS-60000 (WorkForce DS-60000); Epson DS-6500 (WorkForce DS-6500); Epson ...
Feb 26, 2015 | Epson WorkForce DS-6500 Flatbed Scanner -...
Cant get my Epson Workforce 633 to print. WILL NOT print black.
check if ink came out of the head or nozzles if not then first open the nozzles and head with warm water.
Feb 10, 2015 | Epson WorkForce 633 All-in-One Inkjet...
EPSON L355 EPSON Drivers and SW
Jan 27, 2014 | Epson Office Equipment & Supplies
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Problems scanning, it used to but not anymore.
I would try this... uninstall the device, then unplug the device, reboot the computer then reinstall the device per device instructions.
Aug 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson workforce 633 warning paper jam when no paper jammed power wifi and fax auto lights flashing can not get to menu
I had success by turning the printer off and on again with the top pieces up (as if changing the ink). I found this trick also works when I have a scanner error that won't go away. Good luck!
Apr 23, 2012 | Epson WorkForce 633 InkJet Printer
Epson workforce 500 will not scan
All is well! I just followed some other person's solution (at a more responsive forum!) by downloading the latest .exe files from Epson and now everything is working just fine. thanks for answering my post above....ha, ha, ha. :)
Jan 21, 2010 | AcerPower Sn PC Desktop
Epson Perfection 1250 Flatbed Scanner Logo
156 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
