Question about Soundcraft GB4 32 Channel Dual-Purpose Consoles Microphone
What does the "EQ" button do?
  • 3 Answers
Its as simple as it looks. Th eq butom activates the EQ control. Turning it off bypasses the EQ which is helpful for comparative listening. A lot of destruction can be done with improper equing so sometimes its a good idea to just turn it off and evaluate what the recording originally sounds like with out being tampered with. Some units have a tuneable frequency selection so you can digitally hone in on the desired frequency range that you want to bump or reduce but those are labeled frequency more often than not.
Posted on Dec 30, 2010
Where is pre out im having trouble hooking up amp and eq
You have to use the TAPE 2 (or monitor) on the receiver. It will take two sets of RCA cables. Both the receiver and the EQ will have an input and an output.
  • Run the output/REC (from TAPE 2) to the input on the EQ.
  • Then, run the input from the receiver (TAPE 2 again) to the output on the EQ.
The EQ will have another 2 sets of RCA jacks to hook up a second tape deck (because you used the jacks on the receiver for the EQ). You don't have to hook anything to these if you don't want to, or don't have a second tape deck.
The receiver will have a monitor button, which most of the time is labeled as TAPE 2/MONITOR. Select whatever input you want to use (CD, Tuner, Aux, etc.), then press the MONITOR/TAPE 2 button. When that is on, the EQ will be in the audio chain - you'll be able to use the EQ to adjust the sound. If you turn the MONITOR off it will take the EQ out of the audio chain - the EQ settings won't affect the sound.
Keep in mind, the EQ will also have a button to select the TAPE 2 input. If you have a second tape deck hooked up to the EQ, this is how to use it. Make sure that the tape input is off on the EQ, if you aren't listening to that second tape deck.
Mar 09, 2016 | Audio Players & Recorders
Hook up kenwood ge-1100
2 stereo rca cables tape out to line in on eq, line out from eq to tape in on receiver. press tape monitor button to use eq, turn off tape monitor for direct. some receivers also have a dedicated I/o for eq, you just need to remove the jumpers and install in that loop (out to in on eq out from eq to in on rcvr}
Mar 16, 2014 | Kenwood Ge 1100 Graphic Equalizer
Audio Output Non-Functional
Yes. Take it to the repair shop and have yet outputs fixed.
Feb 27, 2017 | Kenwood Stereo Graphic Equalizer - Ge-76
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
Can't get the stereo out of "demo repeat play" - it won't even turn off. If I unplug it, it automatically comes back on in "demo" play when plugged back in
It's in the manual, page 24.
DEMO
Press EQ master on the front panel in power off state to demonstrate the function in the display window. To
cancel it, press POWER or EQ master again.
May 29, 2011 | LG LFD750 Shelf System
I am using the "
http://www.retrevo.com/support/Yamaha-RX-797-Receivers-manual/id/320ag612/t/2/
I assume you've placed the Bose Active EQ in where the Pre-Out >> Main In jumpers were. Do you have the return from the Bose Active EQ going back into the Main In so it can continue to the Sub Output.
Or do you have the Bose EQ Tape Switch activated incorrectly?
Feb 03, 2011 | Yamaha RX-797 Receiver
Hi I have been given a telescope but no assembly instructions and the only markings on it are "Atlas Explorer" & "D=60MM F=900MM Coated Optics Made in China" Would you know where I...
That is NOT an Atlas EQ-G as your question indicates -- this is an atlas eq-g-
http://www.telescope.com/control/accessories/mounts-and-tripods/orion-atlas-eq-g-computerized-goto-telescope-mount
This is a 60mm refractor style telescope imported from China. No one will have a manual for that scope. Try to locate a local Astronomy club and the members will help you assemble it.
Nov 20, 2010 | Orion Atlas 8 EQ-G Telescope
Cant hook up eq 2 kenwood vr 505 reciever
on the reciever connect patchcords from the tape out to the line in on the eq than line out from the eq to the tape in on the reciever --when you turn on the tape monitor button then the eq is engaged --enjoy
Sep 08, 2010 | Kenwood Audio Players & Recorders
Need help on setting custom EQ for my JVC KD R506 in car music system. m not able to find the settings. also any idea how to increase the bass effect from the speakers. can i connect a subwoofer without an...
Set your equalizer to you a V shape or U shape pattern, bass effect can only attain by adding a powered subwoofer, (amplifier and subwoofer). subwoofer without an amplifier doesn't sound good, your system doesn't have enough power to drive your subwoofer.
Jun 23, 2010 | Car Audio & Video
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
98 people viewed this question
Top Soundcraft Audio Players & Recorders Experts
shaqsatin
Level 1 Expert
Gil Shultz
Michael P
Level 1 Expert
Are you a Soundcraft Audio Player and Recorder Expert? Answer questions, earn points and help others
