Question about Lands Phones
We have a tevion dp750 phone. it is set at pulse and we want to alter the setting to tone to accept calls. Please help
  • Anonymous Dec 28, 2008
    we have
The manual says -
1. from standby, press and hold <| until the setting you want is displayed : pulse or tone ( the symbol is the backwards facing triangle)
If the setting displayed is not the one required release the button, and then long press it again and the setting will toggle
Posted on Mar 15, 2009
On the handset, below the screeen in the left corner is the R button (left to Talk) green button. Press and continuously hold the R button uless changed to pulse/ Tone
Posted on Feb 13, 2013
2 Suggested Answers
SOURCE: tevion dp750
From standby, press and hold < until the setting you want is displayed: "Tone" or "Pulse"
Posted on May 13, 2010
I have a Serene CL-60AP phone. It receives calls but I can't get it to dial out. I hear it dialing like an old rotary phone but then the dial tone comes back.
You need to change the dialing mode to tone rather than pulse.
If you would like to know how to do this refer to page 26 of the instruction manual
50. DIALING MODE SETTING (TONE OR PULSE)
page 15 on the pdf file below
http://hearinglosshelp.com/store/wp-content/uploads/sites/2/2015/02/CL60Ausermanual.pdf
Depends on what your telephone exchange accepts as a dialing signal. Strange thing is phone is factory set to tone but it seems to sound like your phone is on pulse.
Mar 11, 2017 | Lands Phones
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
NO RINGING TONE
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
Jul 18, 2008 | RIM BlackBerry Pearl Smartphone
Tevion dp750
Jul 07, 2008 | Lands Phones
Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
May 26, 2008 | Panasonic KX-T7730 Corded Phone
Switching from pulse to tone and reverse
once tone/pulse appears there should be a way to hi light/select or choose either one.you must set it into memory. after it is stored, you shouldn't have to set it again before making other calls.
hope this helps
wg
Feb 10, 2008 | GE 29385GE1 Corded Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Lands Phones Logo
406 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
