Question about Dell E177FP LCD Monitor
ON/OFF Button is stuck ... in the "on" position,
  • 11,361 Answers
You will have to open it up and get to the front bezel where the switch PCB assembly is screw down to the front bezel with VERY FRAGILE ribbon cable.
It may have broken plastic actuator on the button that makes contact with the TACTILE switch, the plastic assembly is not available as far as I know.
You may also want to inspect the caps.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E177FPv/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Posted on Dec 30, 2010
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 | Irons
Monitor On/Off Button Stuck
Get a stiff paint brush and cut the bristles down then run the bristles around the switch. it will (should) clear any debris that is causing the switch to stick.
Apr 01, 2013 | Computers & Internet
Pinch roller stuck in "up" position, eject button won't open door
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Dec 03, 2012 | Audio Players & Recorders
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
Jan 11, 2011 | Oster 5965 Electric Kettle
Insinkerator stopped working. Cutting plate rotates freely. tHE RESET BUTTON IS STUCK IN THE "ON" POSITION.
If the reset button is stuck in the on position and can not be reset, the motor has an internal overload and will need to be replaced. Turn the power off to the motor via switch or circuit breaker, let it cool for awhile, the hit the reset button again to see if it resets. If it does, turn off the power at the breaker and leave it off. At this time, you need to dislodge a jam on the rotary vane that shreds the waste, there is something most likely stuck on the vane, causing the motor to overheat. There should be an allen wrench socket area in the middle of the underside of the motor housing, use an allen wrench and turn the motor manually back and forth, to release the jam. Again, be sure the power is OFF!!!
Dec 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Power button stuck in 'Off' position
My CHI button is stuck on off, how do i fix it ?
Aug 01, 2009 | Wahl Health & Beauty
Stuck shutter release button on my D100
Ouch...
The damage may require parts, but maybe not. If I were doing the work, I would charge in the $50-$60 range , plus parts if needed.
Nikon will likely quote you much higher $200+
You can use the repair service locater here on Fixya to find a repair shop in your area
Mar 24, 2008 | Nikon D100 Digital Camera
Dell E177FP LCD Monitor Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
