Question about Reddy REDR40T Heater
Fan kicks on and heater will not ignite - Reddy REDR40T Heater
  • 674 Answers
Remove the top of the heater and turn it on. Look for the igniter to start sparking if it uses the spark plug type igniter or if it uses a HSI type, look for it to start glowing. Next, use a flashlight to look for fuel spraying out of the nozzle. If it isn't check the nozzle for a clog. Check the fuel filter. Remove the filter cover on the back of the motor and check the air filter. If this doesn't get the fuel going you will need to get a pressure guage to screw into the left hole in the filter cover and check the air pressure going to the fuel nozzle. It should ~3.5#. You can adjust it by turning the adjusting screw in the other hole in the filter cover. That plug should have a hole in it.
Posted on Dec 30, 2010
Turn on heater, it does not ignite, but the fan kicks in and sprays fuel out the front
It sounds like you either have a bad ingitor or bad ignitor adjustments. I'd suggest calling a service tech.
Dec 03, 2014 | Heating & Cooling
Not sure what type heater you are asking about. If oil furnace, then the igniter rods need to be resharpened and adjusted into proper alignment.
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
My furnace blower kicks on and the flame lights for about 5 seconds then kicks off. I replaced the igniter recently. The service trouble light blinks continuously.
Your furnace may be kicking out on high limit. Its possible your circ. or blower fan needs to be cleaned. If you don't get enough air moving across you heat exchanger it will kick off on high limit.
Jan 14, 2011 | Goodman GMS90703BXA Heater
Our fan wont kick on , you can do it manually
sounds like your plenum temp sensor is pooched. once your plenum gets to a certain temperature then a sensor closes, telling your fan to turn on, if the fan doesn't turn on then the flames will be shut off by the high limit switch witch prevents your plenum from burning up.
Jan 24, 2010 | Coleman Propane Forced Air Heater...
Fan kicks on, hear a click about 10 sec's when the heater should normally kick in. It is blowing air, fan works but no heat. Been using for a month ok, used last three months when new last year
You may just be out of gas or a valve may be off. If not you need to look for a ignition problem. A bad glow plug or no pilot. The fact that your blower works and the click you hear narrowes it down to these two things. Good luck.
Jun 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
Dayton 3E372B Fuel Trimmer
sounds like the thermal couple could also be the ignition module.Is it spark ignition or hot surface
May 05, 2008 | Dayton (3E379) Heater
Reddy REDR40T Heater Logo
237 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
