Question about Canon HG10 HD AVCHD HD Camcorder
I have a Canon HG10 and my mic input is not picking up sound. It works before and I suspect that I overloaded the circuit using "line" input level without an attenuator. Would this be an expensive repair? Joseph
4 Suggested Answers
  • 35 Answers
SOURCE: canon optura 500
I believe you need a stereo mic. This will have two black rings around the male input. When you plug it into the camera, it will "disable" the built-in mic. I don't believe it will matter if the attenuation is on or off.
Posted on Jul 01, 2007
SOURCE: regarding the canon hv20 camcorder.
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Posted on Dec 03, 2008
SOURCE: Canon Hg 10 Vertical line on image
This camera outputs interlaced video files. That can be the lines you are talking about if you are playing it back on a PC. The camcorder itself will de-interlace the video during playback on the actual camera, but not the file. You have to either play it (60i) with a hardware or software player that de-interlaces in realtime, or export your video file into a progressive (or deinterlaced) format. Some cheap editors dont deinterlace. I use Adobe Premiere Pro and Sony Vegas.
Posted on Jun 21, 2009
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
My Dell Dimension E510 cannot pick up any voice recording from my various mic inputs. I have fiddled with volumes of each respective input (line in, rear mic, mic jack) to no avail, and when I try to use...
This sounds like you have a voice morphing program installed. A morph program is useful for distorting your voice and special effects, but it also takes over your mic controls. Go to the control panel and choose sounds and audio devices, then look for the default device under sound recording and make sure your record device is the same model as your sound device and that it says INPUT. Another problem occurs if you right click your little sound/audio icon on the taskbar and choose open volume control then left click. Do that now and choose, options, then properties. Now on mixer device, choose one that says input. The white window on the bottom of that panel will show you several devices, check mark them all and click ok. Now manually select MIC as your default sound input device and close then try again.
Mar 09, 2010 | Dell Dimension™ E510 PC Desktop
Tried to use mic, only picking up computer sounds.
Ensure that you have selected the Microphone or the Line-in as your recording input. It sounds like you have set STEREO MIX as the recording input. Double click your speaker, select from the drop down "Properties" then Adjust volume for (RECORDING) select that and ensure that your appropriate recording device is selected. (XP)
Jun 30, 2009 | Dynex Audio Players & Recorders
Dec 24, 2008 | Canon MV700 Mini DV Digital Camcorder
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
if you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
Sep 16, 2008 | Canon HV20 HDV Digital Camcorder
Open Questions:
See all Canon HG10 HD AVCHD HD Camcorder Questions
Canon HG10 HD AVCHD HD Camcorder Logo
74 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
