Question about Goodman GPH1324H21A WallWindow Air Conditioner
Condensor fan won't run - Goodman GPH1324H21A WallWindow Air Conditioner
  • 2,133 Answers
Replace new capacitor.
Posted on Dec 31, 2010
Condensor Fan won't stay running
Check capacitor if its good its the motor
Aug 30, 2012 | Gibson Heating & Cooling
No ice
The service light flashing usually indicates that there is a rise in the temperature of the machine, most likely caused by either the condensor coils being dirty or the condensor fan motor not running, either of which cause the compresor to run hotter than normal. The ice maker itself won't operate if the temperature rises above 10 degrees F, which is still well below freezing but its a fail safe to prevent flooding in the machine. I would take off the removeable grate and check the coils and clean them before I call anyone.
May 08, 2012 | Sub-Zero 642
The condensor fan on my 2005 nissan armada won't
There is a recall on those fans. I would check with your closet Nissan dealership to see if you have an open recall on your truck.
Jul 18, 2011 | 2005 Nissan Armada
My refrigerator freezer does not cool below 70 degrees. I just relace the start relay and now the compressor runs but the condensor fan won't work unless i give it a little spin.
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Oct 15, 2008 | Refrigerators
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Open Questions:
See all Goodman GPH1324H21A WallWindow Air Conditioner Questions
Goodman GPH1324H21A WallWindow Air Conditioner Logo
49 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
