Question about Solis Coffee Makers & Espresso Machines
I have a Solis Scala coffee grinder with a broken mechanical timer and have searched all morning for a supplier of a new wind up mechanical timer in the sydney area but to no avail
SOURCE: Solis Master pro coffee machine
Go to http://www.soliscoffee.com/doyouneprowm.html choose the manual for the machine
Posted on Jun 19, 2008
mirran
  • 515 Answers
SOURCE: Solis rapid Steam stuck in descaling cycle
try to run a new descaling to see if it works normal again.
/Mirran
Posted on Sep 22, 2008
I hope you found your answer in the meantime. If not, here's a page of manuals from Soli. The Master pro does not seem to be in english, but your problem might be covered in a similar manual. Here's the link:
http://www.solis.ch/kundendienst/kdienst_manuals_body.htm
Collette
Posted on Dec 24, 2009
  • 1089 Answers
SOURCE: service solis master pro
Hi
Contact Quality Coffee Systems in Burnaby, BC qcs@telus.net
Posted on Dec 29, 2009
SOURCE: Mr. Coffee coffee maker replacement decanter NOT available ISD 17
I am in your boat! I have been searching for ISD17 for my dust collector, for 3 months now. I have called Mr Coffee, they told me the item would be available August (end of) and nothing. If I hear anything of find I will for sure come back and post! Although it doesn't solve your problem, I just thought you would like to know you are NOT alone.
Posted on Aug 28, 2010
I have got a master 5000 and the brew unit gets jammedor locks when goes on brew mode.
Hi
There are a couple (3) of things that can cause this.
1. You have a broken brew drive but you would hear a clicking noise if this happens.
2. You have an over charge going into you brew unit. There is a small knob in your bean hopper. Turn it back 1 mark and try again.
3. Your grinder has come apart and is grinding very coarse. (French press size) New grinder.
Jun 01, 2011 | Solis Master 5000 Espresso Machine
Timer knob is broken, I need a replacement
Hi Contact Baratza at 877-701-2021 They should be able to help.
Feb 06, 2010 | Solis Maestro Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
My Solis Maestro grinds but produces only about
Hi
I would say that your grind adjustment ring is broken inside and needs to be replaced.
Contact Baratza at 877-701-2021 Mon. thru Fri. 8:00 to 5:00
Nov 14, 2009 | Coffee Makers & Espresso Machines
Poor grinding
Hi
Try calling Baratza at 877 701 2021. They should be able to help.
Aug 28, 2009 | Solis Maestro Electric Burr Grinder
The grinder on my solis digital master 5000 winds but does not grind.
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jun 14, 2009 | Solis Master 5000 Espresso Machine
Grinds coffee too coarse
Hi Sounds like you have a broken grind adjustment ring. You should contact Baratza and see if you can get a replacement. 877-701-2021 8:00am to 5:00 PST Monday thru Friday.
Jan 13, 2009 | Solis Maestro Electric Burr Grinder
/Mirran
Sep 22, 2008 | Solis Palazzo Espresso Machine
The timer knob broke - can't find replacement
Assuming it has broken on the shaft then you could pry the broken bit off the shaft and take the knob and broken piece to your domestic appliance parts stockist. The shafts are usually a standard size and there might be a similar knob that you could replace it with.
Oct 02, 2007 | Solis Maestro Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
205 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
