Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
My printer keeps saying to Load Paper: A4 then Change Reg'd Size - Common Settings I have letter paper in it and it will scan and print, but not print from a computer. I push the setting buttons and I'm lost... help!
IB4G2008
  • 3587 Answers
SOURCE: Problem Priniting on a Non Standard Paper Format with IP5200
the issue here is whether your canon can handle that size of paper. is it running on the manual insert tray?
when you choose paper source, you'll need to identify where the paper is coming from..
try that..
of course, up to date drivers are here
Posted on Feb 28, 2008
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Gort007
  • 1187 Answers
SOURCE: whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Posted on Sep 25, 2009
iservice
  • 318 Answers
SOURCE: I have a Canon Image runner 1023. when I print i
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Posted on Dec 09, 2009
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Paper out message, wanting A4 size
Hi rmfgco2009
A4 paper is 8.3"x11.7" OR 210x297
Letter size is 8.5"x11" OR 216x279
So your paper is called LETTER size not A4
What you have to do is;
  1. On the LCD display of the printer, through the SETUP, change the paper size from A4 to LETTER. Save the settings and Exit.
  2. Also, From the Control Panel, printers, properties, preferences, features change the paper size to LETTER. This step can be done from EXCEl also through the printer menu.
  3. You may need to Turn the printer off and on again.
Hope this will work for you. If this solution is helpful, please give a rating.
Have a Good Day
luciana44
Nov 30, 2009 | HP LaserJet 4 plus Printer
Whenever i change paper size from A4 to letter,
Go to [Start]
Select [properties]
[Advanced}
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Printer keeps saying change paper size
Go to Control Panel - Printers and on MF3310 right click and choose Default settings. I had to change page size from Letter to A4 and output size from Match page size to A4 as well. Finally, after 4 hours of investigations it worked.
Jan 30, 2007 | Canon MF3110 All-In-One Laser Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
384 people viewed this question
old marine
old marine
