Screen flashes -- 8* please wait ---. no buttons work, not even power off. before this it read "Resetting" for a long time
  • 2 more comments
  • c_lanham Dec 30, 2010
    Sorry. It was in the original search and I thought it would stay with the post. It is a JVC SR DVM 700 DVD/Mini-DV/HDD recorder. It counts down from 16 and stops at 8 when power is removed and replaced.
    Do you need more information?
    Clark
    The screen said "resetting" before this happened if that helps. This is a JVC DVD recorder SRDVM 700. It counts down from 16 in an initializing start up mode but stalls at the number 8 and flashes Please Wait.
    Thanks for any help
    Azraelsrl gave me the reset process, which is what I was looking for. Although it did not correct the problem it pointed out my options. Thanks
  • 11,800 Answers
It appears that the processor can't load the firmware after a reset. The only thing you should do is to perform a new reset: with the buttons on the case press On/Off to turn off the unit, press and hold On/Off, then press Stop for two seconds or more.
If this doesn't fix it then either the firmware is corrupt and it will have to be reloaded by a service center of a dealer or the processor itself has failed. In that case the unit is dead: to replace the processor you must replace the mainboard as a whole, and that would cost more than a new unit.
Posted on Dec 30, 2010
  • 10,515 Answers
Kindly mention the make and model of the TV?
Thanks and Regards
taran_2005
My tv power button is just flashing not switching on
Try resetting it by unplugging and waiting 60 seconds before plugging it back in.
If that doesn't work, most likely the power supply board needs to be replaced.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 20, 2016 | Televison & Video
Please restore my Internet Explorer no. 8 for me. Microsoft installed #9 without my asking. I want my full screen back!
oh ****, that's a bummer. give this a shot:
click the start button (bottom left windows icon)the type "programs and features" and hit enterthen on the left hand side of the window click "view installed updates"scroll down the window that appears until you see internet explorer 9right click then select "uninstall", when you are prompted click yes
finish by restarting your computer and you should be all set!
Mar 07, 2012 | Microsoft Internet Explorer 8
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
Sony Touch Screen in camcorder hc26 do not work. thanks
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 28, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
I,ve not been able to see anything on "DCR-HC32 -HC-42" LCD screen, but its working properly if we press it blindly, otherwise its viewfinder is o.k
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
Feb 08, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
TOUCH SCREEN DOESN'T WORK TO PLAY VIDEO
Jan 27, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
MY SONY CAMCORDER DCR-HC20 TOUCH SCREEN IS NOT WORKING
Jan 15, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Touch screen no longer works on Sony DCR HC26
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Note: In the above picture, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15seconds, turn the Power switch to OFF position and then reinsert the batterypack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 13, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
