Question about Maytag Performa PAV3200
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Posted on Feb 09, 2011
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
Asko WCAM1812 makes noise when draining
I recently had this same problem. There is a spinning wheel inside the pump that has likely detached from the motor. Upon removing the back of the unit, you will see a water pump on the bottom left of the unit. There are three screws attaching the pump to the rest of the assembly, remove the screws and detach the motor, out should pop out a red spinning wheel. I Gorilla glued mine back on, and it sounds better than before the grinding noise.
Feb 13, 2013 | Asko WCAM1812 Front Load Washer / Dryer
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Machine makes a mild grinding sound and won't spin in the spin cycle. What could it be?
Welcome to Fixya.
Depending on whether it is a frontload or top load machine has a lot to do with my answer, but for the sake of guessing I`d say check your drain pump.
Both top or frontload machines rely on the unit draining to allow them to spin properly. The "mild grinding" sound may be something in the pump preventing it from draining or the pump impeller itself is grinding.
If you`re not sure how, please specify if it is a frontload or topload and the make and model number and I should be able to help you from there.
Good luck.
macmarkus :)
Jul 14, 2010 | Washing Machines
Our maytag proforma machine was making a loud noise during washing cycle. water wasn't draining - we think it may be the water pump?
Yes, it sounds like you need to check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port of the pump. Check for anything clogging the pump (like the occasional stray sock) Also check the pump impeller. Make sure there are no broken/missing blades and make sure the impeller spins freely. If any blades are missing/damaged or if you cannot get the impeller to spin freely, then the pump is bad. Hopefully it is just a clogged pump. Hope this helps and best wishes.
Aug 30, 2009 | Washing Machines
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
854 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
