Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Are there concerns with toilets which have a lower water tank height to fill the toilet bowl when efficient flushing is needed?
    Sergeant:
  • 182 Answers
I would say that there are no concerns that are not a concern with most of the new toilets of today, regardless of tank size it should always be designed to hold more than 1.6 gallons of water. The key is to find a toilet with the largest flush flapper as you can allowing all of the water to be used quickly and effectively. hope this helps.
Posted on Dec 29, 2010
AquaSource High-Efficiency 1.6; 1.1-GPF (6.06; 4.16-LPF) White WaterSense Dual-Flush Elongated Chair Height 2-Piece Toilet from Lowes that won't evacuate the bowl during a flush.
The flapper may be closing before the tank is dumped completely. You can verify this by observing flushing action with the tank open.
Apr 13, 2017 | Maximum Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
CAN THE TOILET BOWL WATER LEVEL BE ADJUSTED?
Not sure on that toilet but you can fill a water bottle with the desired amount of water and then stick it in the tank thus tricking the toilet to put less water into the bowl with each flush. If you want more water though I am not sure how to do it.
Jun 11, 2011 | Pegasus Technologies Two-Piece Round...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
The bowl will not hold water. This is the second toilet we tried because Kohler thought it may be a faulty tank but same problem. Everything works correctly in the tank but after flushing the bowl will...
the tube that goes from the fill valve to the fill tube may not be installed correctly. the water must be going in the tube and not the tank. also it is a water conserving toilet so it uses less water also it is a comfort height toilet and to make it taller the bowl is extended so the water may seem even more shallow.
Jan 18, 2011 | Kohler Highline - Comfort Height Two-Piece...
How to fix fill water shooting up and over when flushing?
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
Mar 19, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Water disappears to below the bowl inlet and stop.
adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Nov 17, 2009 | American Standard Cadet 3 Right Height...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
153 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
