Question about Dryers
My Kenmore gas dryer runs for 30 seconds and then stops. I ordered a new motor control board but replacing that part did not help. Sanjeev
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
10 year old sears kenmore elite dryer, PF light will not stop flashing even after holding start for 10 seconds or after holding stop button for 10 seconds
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Dryers
Dryers stops after 30 seconds of running.
#5 post_old.gif September 24th, 2009, 08:49 AM jake.gif?dateline=1263924303 Jake user_offline.gif Appliance Tech - Admin Join Date: Aug 2004 Location: Springfield, Oregon Posts: 32,822 Thanks: 48 Thanked 1,244 Times in 1,238 Posts reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_highpos.gifreputation_highpos.gifreputation_highpos.gif icon1.gif So you need the motor control board #17 here?
http://c.searspartsdirect.com/lis_pn...2059-00001.png
Here's the motor control board for your model:
Manufacturer's Number: 8544799
Jun 30, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Drain light is flashing
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30.
Thanks
Oct 20, 2009 | Kenmore 73952 Gas Dryer
Dryer heats for a bit then stops.
Looking in the wrong place. i see this 3 to 4 times a week. you have a bad motor. Motor will continue to run if the gas does not light. Just like it runs on air only. The motor stops due to internal switch that keeps it from catching on fire. Sorry someone put you on the wrong track but you will need to replace the motor.
Please rate this solution if helpful.
Aug 25, 2009 | Kenmore Dryers
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Dryer shuts off.
Did you get this fixed? If not can you hear the timer motor still humming? I'll need to know a bit more to help. Sorry it took so long to get back to you I have been sick for the past few months.
Jul 16, 2008 | Kenmore 73932 Gas Dryer
Electric kenmore dryer
replace the motor it is stuck in the start winding and can cnot get up to the run winding as long as you are holding in the start button the start winding is working in a second it should through the motor switch shift the voltage to the run winding
bad motor switch
replace switch if available or change motor
Apr 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer won't stay running
You need a new thermal fuse. The fuse is located on the blower wheel cover. This fuse cannot be re-set. Replace if open (there is no continuity between terminals). Part number is AP3132867. It is a Whirlpool part but it is the one that fits most if not all Kenmore/Whirlpool dryers.
Dec 08, 2007 | Kenmore 73932 Gas Dryer
Kenmore 110.78932790
Bob, glad you stopped the check, sounds like you need a even heat board. If you press and hold the start button the unit will run. As soon as you release it it stops. Tell the pro you would like a refund. Your part number is 3402605. The board is easy to replace. check out the pic. Catriver
Aug 14, 2007 | Kenmore 72062 Gas Dryer
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
