Question about Bachmann James The Red Engine Train Set
I have a large scale 2-4-2 Bachmann steam locomotive which has a broken drive gear on the rear axle. If I can get a replacement gear, how do I remove the drive wheels to slide the gear on the axle?
2 Suggested Answers
  • 135 Answers
SOURCE: bachmann overland locomotive has trouble staying on tracks
hit it with a bigger hammer!
Posted on Feb 19, 2009
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
www.bachmanntrains.com/.../EZ_Command_instru...
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
www.bachmanntrains.com/.../449105-AMPInstructi...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
Jan 08, 2016 | Bachmann Ho Bachmann Thomas and Friends...
Broken idler/reduction gear in ho power truck
Hi Jerry-
Split gears, unfortunately, often occur with plastic gears especially the older an engine gets it seems. They get brittle and crack.
I've provided a link to the Bachmann website-they offer a catalogue of parts and may have the replacement gear you require. You can also call them toll-free (the number is on the site) and provide the nice person with the model of your engine.
A little known fact is that Bachmann used to provide a lifetime guarantee on their locomotives. If the part you require is no longer made, they sometimes offer a replacement engine (new) at a substantial discount. You will have to mail in your old one. I used this service one time and received a brand new engine for about 60% off the cost of it new. A good deal!
My only other suggestion is to check in your area for local model train shows. You can search for them online. Most of the vendors are hobbyists themselves that sell model trains and supplies to make a few dollars on the weekend. Their trains are usually used but sell for a fraction of the price new. Sometimes you can purchase a beat up engine for its parts for a couple dollars, and sometimes they have parts that have been taken off used engines themselves. Bring your engine along with you and see what you can find. I find bringing an old engine back from the dead always very rewarding! Hope this helps! Happy modeling!
Bachmann Trains Online Home
Apr 01, 2014 | Bachmann Crafts & Hobbies
How to replace rubber wheel rings on a bachmann 0-6-0 ho scale steam engine
carefully remove the drive rod from the wheel, slip traction tire on the wheel and into groove in the wheel, replace drive rod. play with your train!
Feb 03, 2014 | Bachmann Ho Scale Trains Steam Engine...
Replace rubber tires
remove screw that attaches the side rod to the drive wheel, place traction tire in groove in drive wheel, replace side rod & screw.
Feb 03, 2014 | Bachmann Ho Usra 0 6 0 Steam Locomotive...
Want to sell my first generation Big Hauler G scale set. Pristine. In original box. Complete with extra track. How much is it worth?
The Generation 1 Locomotive, is of minimal value.
Best bet if you want to sell the set is to part it out and sell the cars separately.Locomotive, & tender w/rc transmitter ~ $15.00 - $25.00Cars ~ $20.00 - $25.00Track ~ $2.00 - $2.50 per section.If sold as a set, probably would be lucky to get ~ $50.00
Apr 03, 2012 | Bachmann Big Hauler Radio Controlled Train
Where do I send a Bachmann for repairs
Contact Bachmann Parts & Services & they'll give you shipping information to get your locomotive repaired.
1-800-356-3910
Jan 21, 2012 | Bachmann Toys
Locomotive no longer smokes
If the smoke unit was working, and no longer does, it may be burned out. Did you turn the unit off after running it out of fluid? If not, it will need to be replaced. The switch is behind the smokke box door on the front of the boiler. I'm not sure if the smoke unit is a warranty replacement part, but a check with Bachmann Parts & Services & they will give you an answer.
http://www.bachmanntrains.com/home-usa/prod_serv.php
Your Locomotive is commonly called the Bumble Bee.
Jan 14, 2012 | Bachmann G-gauge Big Hauler - Ebt Boxcar...
What kind of lubricant do I use for a Bachmann EMD GP40
A light- plastic compatible oil for the wheel bearings, (a drop on a tooth pick)
grease for the gears- a very small amount, a plastic compatible grease
DO NOT USE 3 in 1 oil or WD-40.
lubrication kits are available at your local hobby shop
or online train dealer...
Labelle, Bachmann, Atlas all offer lube kits.
Oct 09, 2011 | Bachmann 63598 Alaska Emd Gp40 Diesel...
Bachmann James The Red Engine Train Set Logo
118 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
