Question about Uniden Atlantis 250 Marine Radio
Atlantis 250 - have no squelch when unit is on. Battery is charged but can not receive or hear transmissions ie weather reports. Any suggestions?
Me too. Also, transmit seems to work fine but the battery level indicator drops a lot after a few short transmissions.
Posted on Jun 13, 2011
Sends but will not recieve
If the receiver makes noise with volume up and squelch down, then the receiver itself is probably damaged and typically not worth the expense of fixing. If you can't get noise, it may be the speaker. Some models have an external speaker port you could try.
Apr 10, 2014 | Uniden Atlantis 250 Marine Radio
Icom m36 will not receive. Speaker makes noise with squelch all the way up but just won't receive anything including weather.
You may have the CTCSS tone squelch enabled so unless a station you're listening to is encoding CTCSS tones, you won't hear the traffic you're expecting.
Oct 28, 2013 | Icom IC-M36 VHF Marine Radio
Atlantis 250 will receive but won't talk out, could this be a faulty push to talk button?
Are you sure it isn't transmitting? do you have a PL encoded on the radio you are using as a receiver? disable it so you can hear everything on it. the wrong digital squelch settings between the two radios will make it look like one of them is not transmitting.
Oct 23, 2013 | Radio Communications
Cannot receive weather channel information
Antenna connected? Station off air due to bad weather? Is the 'squelch' set to you hear static, then turn it back just to where it stops hissing? Try that and let me know.
Feb 21, 2013 | Uniden BC60XLT Handheld Scanner
Uniden Atlantis handheld. Battery went flat and I lost charger. Have tried to charge it with cigarette lighter attachment. Screen lights up and it bleeps etc, but no radio reception and no static when I...
You may have blown the speaker. First I would check the speaker, unpluging the speaker two wire jack the speaker should read 8 ohms with a meter sat to ohm. Good luck.
Mar 07, 2011 | Uniden Atlantis 250 Marine Radio
I am able to transmit but not able to receive on this model and the squelch is very low, can you help me resolve? I am not receiving any weather transmissions either.
Hi, my name is John. Check your antenna that it is getting a good connection,and that it is grounded. Turn your RF GAIN to MAX. Turn squelch all the way to the left. To hear Weather, Press the Weather button. hope this was very helpful.....rate this solution on the four thumbs-up.....John
Sep 08, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
My Oregon Scientific WR602 frequently loses it's settings and I have to reset it before it will pick up the NOAA again. Once I do that everything is fine for a while, then it loses it's settings again and...
It happens, and can be discouraging at times. Not sure what your locale is, but there are certain geographical areas that are more equipped with towers to create a more stronger and consistent signal, whereas there are also areas that have less towers that create a weaker signal. If you are noticing that your WR is frequently losing a signal, or are receiving consistent white noise/static, you might try moving your WR device into a different location. It may take some test time at each location.
Here are some other tips:
1) Make sure your WR is placed in a location away from the use of too many electrical devices. Sometimes, just plugging your device away from your computer, desktop telephone, answering machine, and other electrical devices will frequently solve the problem.
2) Try stationing your device to a higher location. If you have a 3 story home, consider placing it in the upstairs. Same applies with lower levels. If you have a one story home, try stationing your weather radio higher up and test your signal then.
3) Make sure that your WR is capable of receiving a signal. The best signals are typically reached when the receiver is placed near a window with no visible interference blocking the transmission.
4) Make sure your battery is charged or unit is placed in the charging base to receive a solid signal.
5) Make sure your location and channels are set correctly. If you set your location to AUTO, you should have no problem hearing weather reports for your area. If you would like to hear the weather report for your county only, call 1-888-697-7263. Follow the prompts through a simple voice menu.
(OR) go to www.nws.noaa.gov/nwr/indexnw.htm. Click the state for which information is needed.
Oct 30, 2009 | Oregon Scientific WR602 Weather Radio
Constant beep, channel number and tx flashing
Ok this problem is caused by the spring mic jack
Getting rusty
Oct 26, 2008 | Uniden Atlantis 250 Marine Radio
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Uniden Atlantis 250 Marine Radio Logo
535 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Uniden Boating Expert? Answer questions, earn points and help others
