Question about Polaroid Televison & Video
I have a polaroid FXM2611C LCD TV DVD Combo that I gave to my kids. They are hooking it into just the coax cable. Menu tuning band is set to cable and the input to TV. They get a fuzzy picture. Their old tv worked fine and the smaller polariod I gave them also works fine. Any suggestions.
  • 1 more comment
  • srmaupin10 Dec 30, 2010
    There's no antenna on the house. So, you use that because the signal is now digital and not analog? Just making sure I understand why that input is used.
    I used it with a cable box and HDMI cable with no problems. Yes, we checked to make sure the coax was making contact with another TV and no problems. Thanks for the user manual.
    no antenna on the house. So, you use that because the signal is now digital and not analog? Just making sure I understand why that input is used. I used it with a cable box and HDMI cable with no problems. Yes, we checked to make sure the coax was making contact with another TV and no problems. Thanks for the user manual.
  • srmaupin10 Jan 02, 2011
    Thank you for the solution. They are now enjoying the TV.
  • Polaroid Master
  • 17,130 Answers
Once again test the input source signal strength of the cable line . Once this is confirmed you can connect the line to the combo. make sure that there is a good picture with the DVD played in the combo.
Now make the input to tuning band to TV and test , if so the signal could be in the frequency for the TV bands, If not there can be issues with the tuner which your warranty should take care.
Also check if the oId TV had the cable band or the regular TV bands on which there was good reception.
Hope you check this out and reply.
Posted on Dec 30, 2010
  • Polaroid Master
  • 12,061 Answers
OK NO don't use "Cable" as this isn't the correct Input, you need to use ANTENNA, as this is what the signal is. After hooking up the Antenna wire to the Antenna IN socket, the "Belling Lee" plug on the rear of the unit.
Once hooked up to the correct place, then do a channel search, and you should be able to "Tune" your set.
Always check the Plug end too, make sure that the Plug on the end of the antenna cable is OK, you need to physically check inside. Also check that the center pin is making good contact with the "Fingers" inside the female socket too.
.www.polaroid-tv.com/wp-content/uploads/2010/06/fxm2611c_ug.pdf
Above is your user manual, inside it shows one exactly what and how to do as you wish. Download the PDF and use Adobe Reader to view.
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Why does the menue not display?
Is the RF tuning set up for coaxial?
Sep 11, 2014 | Televison & Video
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a lcd 37" polaroid tv / dvd combo I use to have it hooked up to Direct TV and now wanted to just get the free channels with an antenna. Eveytime I scan for channels it doesn't find any. Do u think...
go into the set up menu and set the signal input to AIR, the rescan for channels. Directv should have been going into a sat box then into a different input than the Ant jack so make sure your on the right input
Jul 16, 2009 | Polaroid Televison & Video
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Televison & Video Logo
140 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
