Question about Sony KP-53V80 53" Rear Projection Television
Top, bottom, and sides of screen are blurry
I think my sony KP-53v80 has some sort of convergence problem. The middle of the screen looks great, but the outside edges are blurry. I purchased a service manual because I saw many people mention a grid to fix convergence problems, but I didn't mess with any of the settings because I'm not entirely sure what to do. I called a repairman and he said it would be over $300 to fix...something about a board that may need to be replaced. Would I be able to fix or replace the board myself if that is the problem? I repaired circuit boards for a few years for work, so I figured it can't be too hard. Can anyone help me?
  • 1 more comment
  • Jesse Scandlin Jul 07, 2008
    How do I do that?
    How can I check if one of the lamps has blown?
    Can it be fixed with the remote? If not, what board, ICs, and/or fuses would need to be replaced and where can I get them?
  • 10,594 Answers
Hello there,
Being a practical technician I would assist you technicaly.
Please find G-Board in your TV and replace IC1502 & IC1506 (STK392-150)
Before replacement of above said ICs, check follwoing Fuses (PS1501-1502-1503-1504-1505 & 1506) all are 2A rating. If you have VOM (Volt Meter) then confirm +15Volt & -15Volt supply on G board. If you need further help, I can provide with pictures of related circuit portion.
Posted on Jul 20, 2008
    Master:
  • 726 Answers
If it blurry there could be a problem with the lamps ,dirt ,dusty outta focus take your tv a part inside is a big mirrior and 3 lamps turn your tv on and look at the lamps (its normal) and see if there all working clean them with a tissue or lint cloth the bulbs are luqid filled so check if there leaking and focus them by the knob around the bulb
  • Sony Master
  • 6,487 Answers
Check this link hope it will help your concern http://lamson.ftp4me.com:8080/MODEL%20LIST/sony%20chassis%20for%20model.pdf
Hope that helps........
Posted on Jul 07, 2008
    President:
  • 2,267 Answers
You should replace both of your STKs 392-120s.these are your convergence ics , I always replace with 392-180s better ics.
This will fix your problem.
  • Jaime Hernandez Jul 07, 2008
    Check your service manual to find the location of these ICs. You should also check the low value resistors that are connected to the ICs as well.
  • Sony Master
  • 19,396 Answers
Perform service convergence setup procedure
  • Ginko
    Ginko Jul 07, 2008
    It is a typical convergence problem. Start performing convergence setup procedure, illustrated in service manual.
    if you still get the problem, it means that probably one of the two convergence ICs has blown, in this case the repairman must test the fuses at the base of the ICs and replace the defective IC.
    If your tv has a separate convergence board you can replace the whole board (part cost $60/$100).
    Check also that is not just one of the lamps that has blown, that will be easier to fix.
    Leave the tv unplugged for over 30 minutes before servicing it, do not work with live electricity unless you are an expert technician.
Sony KP-53v80
There may be an open fuse. The typical fuse for the application is a 3-amp, and may not look anything like your typical fuse. If you have sucessfully replaced the parts that you indicated, the convergence should be very close to what it was before the failure. The fuse may look like a small rectangle of black or white plastic with a wire through it.
Feb 02, 2010 | Sony KP-53V80 53" Rear Projection...
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
I have a sony kp-41t65 tv acting like computer screen out of whac
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Nov 10, 2009 | Sony KP-41T65 41" Rear Projection...
3 different images in color sony kp-53v80
Replace Both of your convergence ICs They are big black ICswill have part number on them STK392-110 Order the same # as your STKs have on them Call Mats for Parts 1-800-628-1118 also CK pico Fuses they look like resistors will be green or yellow they are fuses.
Sep 27, 2009 | Sony KP-53V80 53" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
I have double images in red on my screen any ideas?
You have a convergence problem, time to call for service.
it should run about $300
Jul 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Blurry screen?
there are 3 things that will make your tv go blurry, the focus and screen control assembly , the high voltage splitter and the horizotal transformer and that is only if all three tubes are blurry.if only one tube is blurry, more than likely the tube itself is bad.
Aug 05, 2008 | Sony KP-53V80 53" Rear Projection...
Selective "non-convergence" issues
Sounds like to may have a yoke loose on a tube. If it's not that, you may have somehow damaged the convergence board. Look for any cracks in the board. If you find any, solder across the beaks and it should be fine. Good luck and I hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Sony KP-53V80 53" Rear Projection...
Sony 52"
i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
Dec 28, 2007 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
144 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
