Question about Linksys Wireless-G WRT54G Router
I reinstalled Windows into my computer because it had a virus. I have internet when the PC is connected to the modem. But when I run the linksys setup, linksys does not detect internet connection, so the router will not work. even though right now I am using the internet connection, so I know that is not the problem. Please Help.
  • 591 Answers
Well you'r ISP connection is good since you have internet when connected to the modem (just be verry prudent since you have no security when connected to the modem)
First verify with you'r ISP what type of connection you have (STATIC IP, DYNAMIC IP/DHCP, PPPOE, etc...)
Ask you'r ISP if they can reset you'r account (MAC ADDRESS, PASSWORD, etc...)
You can also verify the connections from the modem to the router (CABLES, CONNECTORS, etc...)
Posted on Dec 30, 2010
My computer is crashing repeatedly do to viruses and other malware. I would like to just pull a complete system restore on it, but in the past my Linksys WMP54GS PCI Adapter has always given me trouble...
at a guess when u format reinstall you are losing the driver for the pci adapter. So get onto another pc download the driver , format restore the pc and install the driver then try to connect to the net , if u are using windows 7 i think the pc would have no trouble fixing this .......
Jan 09, 2011 | Linksys Computers & Internet
Cable provider had to change modem, and now my wireless router isn't reconize how to fis
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Thumbs back!
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
I have an internet connection through my desktop that is plugged into a cable modem but when I run the Linksys Easy setup software it says it can't find a internet connection. I have turned off my Norton...
Make sure connections are correct. Cable modem to router with Ethernet cable. then connect router to computer with another Ethernet cable and see if it works.
o this:
1. hut down computer, modem and router.
2. put them on in this order waiting 1 minute between each.
---cable modem
---router
---computer
you also have to check that the router is set up as dhcp
Dec 26, 2009 | Linksys WRT150N Wireless N Router -...
Slow internet problem i think its my communications card
This document is GENERIC for all types of PC using XP or before. Step 1: Detecting and removing spyware and adware software If the computer becomes slow when connecting to the Internet, your home page changes to a page you do not want, unwanted desktop links display, or advertising windows pop up repeatedly, then your computer probably has spyware, or adware installed. Spyware and adware can be difficult to remove manually. See the following HP support document for more information about spyware and how to remove it from your computer: HP and Compaq PCs - About Spyware, Adware, and Browser Hijacking Software . Step 2: Scan and remove viruses It might be that a virus or several viruses are attempting to use the Internet connection when the browser is open. See the following HP support document for more information about how to scan and remove viruses: Resolving and Preventing Viruses on Your Computer . NOTE: If you have not updated Windows recently using Windows Update (in English), now is a good time; after scanning and removing spyware and viruses . Step 3: Clearing history, temporary files, and resetting settings Clear the amount of temporary files that the browser uses as follows:
  1. Open the browser software.
  2. Click Tools from the menu bar.
  3. Select Internet Options . The Internet Options window displays. Figure 1: Internet Options windowc00162617.jpg
  4. Click the General tab.
  5. In the Temporary Internet Files area, click Delete Files .
  6. Select Delete all offline content , and click OK .
  7. In the History area, click Clear History , and click OK .
  8. Click the Security tab, and select Default Level .
  9. Click the Content tab, and click Clear SSL State .
  10. Click the Programs tab, and click Reset Web Settings .
  11. Click the Advanced tab, click Restore Defaults , and then click OK .
  12. Connect to the Internet. If the computer stops responding, continue to next step.
Step 4: Update the network or modem drivers Updating the network and modem drivers can fix some lockup problems. Install the latest update for your network hardware that you use. Update the network hardware if you connect to the Internet using DSL, Cable, or LAN. Update the modem software if you connect using dial-up.
  1. Go to the HP Software download page . Select your country/region.
  2. Type the model name for your HP or Compaq computer. For example, SR1820NX or m7434n.
  3. Select the version of Windows the computer is using.
  4. Select the network or modem driver update. For example, Realtek RTL8139 LAN Driver Update.
  5. Follow the instruction on the download page to download and install the update.
  6. When done, restart and try to connect to the Internet again. If the problem persists, continue to the next Step.
Step 5: Disabling Software that opens with Windows For troubleshooting purposes, reduce the amount of software that opens with Windows to try and find out if a software conflict is occurring. Open the Microsoft System Configuration software (Msconfig), remove the selection next to Load Startup Items , click OK , and restart the computer. For more information, see Preventing Programs from Opening When Windows Starts . Connect to the Internet. If the computer stops responding, continue to next step. Step 6: Removing and reinstalling ISP and Anti-virus software Remove the Internet Service Provider (ISP) software and install the latest version. Use the document on Advanced Modem Troubleshooting for more information about how to remove and reinstall the ISP software. Regards, Shrey
Sep 30, 2009 | HP 16-Port Ethernet Hub
Notebook will not connect to the internet via modem or notebook card
Hello Sir, Please scan your computer for virus and reinstall the network adapter
May 06, 2009 | Compaq Armada M700 Notebook
Router not connecting to internet modem
This is a tuff router.  I bought it myself hoping for good things, and spent a good two days actually getting the thing to work.
I got mine to work by plugging it into the modem, the laptop I was setting it up with, etc, and then running it all. I would just suggest trying to reinstall it again with everything plugged in from the get go, and then hope for the best.... sorry I cant help more.
Jan 27, 2009 | Linksys WRT160N Wireless Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Lost internet
The usb stick is replacing the job of the card in the pc so it could be faulty, but first reinstall the latest driver for it and give it another try - what version of windowns/linux to do run? What make is the card - (look in Device Manager)? Then I can help further if needed.
Thanks
Jul 05, 2008 | HP Pavilion dv6000z Notebook
I just installed my siemens se567 wireless router nd I want to set up a wireless network to another computer using a linksys wireless usb network card. What must I do?
Hi tbopper, install linksys software. Follow the instruction. Disable your anti virus / firewall software. (temporally). Make sure the PC with the wireless card is turned on.
Than open My Network connections & run windows Set up a home or small office network. Follow windows instructions.
That's it. When you restart your PC your Anti virus software should enable it's self. Check your firewall is also back on, if it's included in your anti virus it will re-inable it's self. Since your running a wireless make sure you enable security & password, other wise anyone with a wireless can tap into your wireless signal slowing your bandwith down.
To test your linksys is correct. Open internet explorer. In the address window type in 192.168.1.1 & press enter. Your settings should show up. Tech support is free with linksys.
Good Luck & Enjoy!
Mike
Mar 31, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
