Question about Car Audio & Video
How do I manually tune to an FM pre set to attach an I pod
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
That all depends on what kind of radio you have.
Posted on Dec 30, 2010
How can i use the remote to play fm again cos it stop working suddenly and start showing PRE 1-15 If i want to press the tuning/ch bottom
You may have to repeat the station preset process. Your unit is prompting you to select a preset station in the 1-15 range.
Feb 11, 2017 | The Audio Players & Recorders
Have lost all my favourite radio stations on honda jazz 2005 how do i retune ?
Select the AM or FM wave band.
Tune the radio to a station then press and hold down the 1 or 2 or 3 pre tune station button until it beeps. Then this radio station is then set to which pre tune button you have selected.
Repeat to set the buttons for other radio stations.
Aug 01, 2012 | 2005 Honda Jazz
I can not get it to work with my pod touch
Plug the device into your power plug in the car. This kind of adapter uses radio frequencies to tune it in so make sure that your radio on your car is set to the same as the device. This will only work if there is no station for that specific frequency - for example, of the device is set to 88.8 FM and there is a local station set to that frequency, all you will hear is static. There is an option on the device to change was frequncy is it set to, tune your radio to the matching number and it should work.
If your problem is getting it connected, there will either be a wire at the bottom to plug into your ipod (goes in the same place as it does when you plug it into the computer) or it will be mounted right on the device. Make sure it is fully attached on both sides or it won't work.
Mar 03, 2011 | Belkin TuneBase FM (F8Z049-BLK) Car...
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Cheers
Graham
Apr 25, 2009 | Electronics - Others
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
20GB IPOD
maybe...perhaps try changing your itunes setting
to
"manually update ipod" if it is set to autosync then all tunes in the library which are registered as being on the pod will automatically update. each time you connect the pod the itunes sw will update the pod from the library.
when the pod is connected and auto sync is active if you delete a tune from the lib it will update the pod and delete the same tune.
Apr 29, 2008 | Apple 20gb Ipod Mp3 Player With Click...
FM or AM
You may have to manually set the preset stations on the unit itself. Read the user manual.
Dec 20, 2007 | Sharp CD-XP120 CD Shelf System
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
