The paper first jammed. Then I couldn't get it to print after i unjammed it. One item is still in the queue, and I cannot get it to cancel out or dlete. The printer willnot print.
  • nealhumphrey Dec 30, 2010
    Yes. restarting the computer solved the problem.
    thanks
  • 4,737 Answers
It would be better for both of us if you did mention the Model and Make of your printer. Well, first of all, press the cancel button on your printer, disconnect the printer from the computer or simply turn it off (or unplug the power cord), after that, restart your computer. Once the computer is restarted, check the print queue and verify it's no longer there. If it's still there, cancel it and once again restart your computer and check (again). This should clear the documents in the print queue. You can now reconnect your printer and resume your work. If this isn't helpful, I would suggest you to uninstall the printer's driver or delete the printer. I hope you know how to delete or uninstall the printer from your computer.
If you need further help, let me know with more details, including the Operating System running on your computer.
Good Luck.
Thanks for using FixYa.
Posted on Dec 29, 2010
How do I cancel documents in a queue
Cheers james heron
To cancel a queued document, there are several ways, it is best to go to printing devices and open what is printing the printer you want to cancel, click Cancel and disappear the document.
In many cases this does not help then you click cancel, the document continues to appear, that's when it works best to turn off the computer and turn it on again.
Another thing you can do to disappear a file from the print queue, disconnect the printer's USB cable and connect it again, for it can do so from your computer or from the same printer.
Another way that can work is, turn the printer off and turn it on again, you should always look the team to lose the memory of what is printed, in order to begin again.
How to delete documents in my printing queue en Rellenado
Nov 23, 2015 | Office Equipment & Supplies
When turned on keeps wanting to feed paper then early paper jam apperrs. how do i fix this
Might have a print job it is trying to print. Clear the print queue and or cancel the print job at the printer. where is jamming could it be the fuser the hot part? if so might have to have it replaced.
Nov 16, 2015 | Xante ScreenWriter (Refurbished) Laser...
How to Cancel Printing in a Brother HL-2135W printer
Start by pulling the paper tray out to stop further pages being printed without jamming the printer up.
Then go onto your print queue on your computer and delete the job that is printing 50 pages.
If it dissapears then put the paper tray back in and it may print out the last page or two that were in the printer buffer.
If it does not dissapear from the print queue then turn the printer off and try to delete the job again.
Once you have ordered the job deleted then you can turn your printer back on and put the paper tray back in and allow it to continue. It should only print out the last page or two and then the job will dissapear
Sep 15, 2014 | Brother Hl-2135w Compact Wireless Mono...
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Lamp of chek a paper is light... cannot to print
Hi Good day!! This error means: Paper out or Paper jam. check your printer if there is a blockage that's why it can't print if there is a blockage 1st thing to do is to turn off your printer and then remove such blockage. if there is no blockage load paper check your printer queue box!! to go to your printer queue box. Click "Start" Click "Settings" Click "Printer and Faxes" there you should see your installed printer check the icon status it should be 0 and ready. if not 0 there is a file that did not finish printing. cancel it just right click your printer and then cancel all. if success your printer should be ok now... hope my solution help you THANKS
Oct 15, 2010 | HP PSC 1410 All-In-One InkJet Printer
Paper Jam
Have you checked for paper jammed in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
Jan 13, 2010 | Brother MFC-7820N Printer
I was in contact with you yesterday over an aspect of the same problem. I printed a very lengthy IRS document, but when finished, the printer tried to repeat the document when I wished to print something...
You will need to clear the printer queue. The instructions for doing so depend upon what OS you are running on your computer, and which make and model printer you have.
Without specifics, I can only instruct you to go to the printer manufacturer's support site online, (like www.hp.com, etc), enter your model number, and search "clear print queue".
You should be able to follow the instructions or solution given to cancel the print job and clear the memory.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | Office Equipment & Supplies
Printer queue jammed
Simply rebooting your computer should fix that. If you have Win2k or XP, you can also open a command prompt and type 'net stop spooler', and when it's done type 'net start spooler'. That stops and restarts the spooler service (which controls the print queue) and may take care of it. But a reboot is easer and more likely to be successful.
Jul 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
