Question about Dryers
Need to replace the belt i know i have got to get it on the belt tensioner and all that but how much of the machine do i have to take apart???
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have to take off the front door main cover. door and cover. you do not get in from the rear
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
What's your problem?nee to know how a tensioner pulley is put together - diagram
Don't believe you can fix them. Just replace it. Tension is critical for the belt to run everything, and to avoid early failure of the belt. A salvage yard tensioner should work.
Jun 22, 2012 | 1997 GMC Yukon
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
The belt has come off the drum and is very hard to put back on . The intsructions say to remove clamp from the motor but there does not appear to be a clamp - therefore whenever the belt is fitted once...
Hi from retired Englishman in SW France @ 14:37 Tue afternoon,
Although I do not know your particular machine-
in general it is always worthwhile purchasing a replacement belt because the old one is likely to come off yet again. In machines I have come across the motor is held in place by bolts which, when tight, 'clamp' the motor in position.
The bolts are loosened, the belt put on and then the belt tensioned by firmly adjusting the position of the motor so the belt is tight and the bolts tightened i.e. clamped
In your case, apart from using the old belt which must have come off for some good reason, it sounds as if the belt is not yet tensioned/clamped.
Have a good look at how the motor is mounted- how it can swivel on its mountings/bolts to tension the belt. The bolts will be tight- and should be when tightened!
Hope this helps,
John C
Feb 01, 2011 | Hotpoint Aquarius WD640 Front Load...
How do you put the belt back on? It was making a screeching sound so I took it apart and now cannot figure out to get the belt tight. I have it back on and back together but do not know how to get the...
you have to open back panel of dryer as well as the top. there will be a spring connected to the motor assembly. unlatch it, check your belt to see if it needs to be replaced. if cracked, replace. latch spring and belt should have tension.
Oct 25, 2010 | GE DWSR463EG Electric Dryer
Can i replace the timing chain tensioner without
you don't have to remove the head to do the timing tension er but will have to do the belt! just get a book and line up the timing marks before you take it apart! good luck
Sep 18, 2009 | Mitsubishi Pickup Cars & Trucks
I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
May 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt slips on the agitator pulley
i got the same problem the belt slips on the spin cycle i have replaced the pulleys the belt and the tensioner worked well for a week then back to slipping took the whole machine apart and found dryed up grease in the top seal and on the shaft cleaned it all of put new grease on worked fine for two months today same thing again took it apart and the shaft is all gross and stickye with dryed up grease i just like to know what grease a guy should use
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
DRUM WON't TURN on my Roper Dryer
you can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Mar 12, 2008 | Roper RES7646KQ Electric Dryer
How do i replace the belt
simple enough the replacement belt hooks around the tranny pulley and the motor pulley, theres tension pulley spring mounted to the motor assy (spring loaded) simply push it in and wrap the belt around the outside of it so when you release it it adds tension to belt, your done!
Sep 28, 2007 | Frigidaire FWS833A Top Load Washer
Dryers Logo
Top Dryers Experts
