Question about Dryers
We changed breaker but it is still not blowing hot air
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
Why does it just blow cool air?
Check outside condensing unit. Should feel warm to hot air blowing out of the top. If cool to outside air temperature blowing off you likely have a refrigerant problem
Apr 02, 2016 | Heating & Cooling
MY DOMETIC RUNS ALL DAY THEN IT BLOWS A BRAKER ONCE A DAY, WHATS THE PROBLEM ? BLOWS COLD AIR
Depending on how hot it is outside, there may not be a problem. It might just be running all day to try to keep up with the amount of heat that's outside. It'll blow a breaker most likely because it's drawing so many amps through the circuit breaker that it trips.
Jul 27, 2011 | Dometic 57915531 Air Conditioner
Haier HR30A1var fan outside is not turning and blowing hot air inside
If you have fuses outside, check or change them..Also check the circuit breakers in your circuit box.
Apr 11, 2011 | Haier HC48C1VAR Central Air Conditioner
Plug heats up, blows circuit breaker
Plug is having loose contact. may be wire are loose inside socket. Tighten them. The contact should be firm not sparky loose.
May 26, 2010 | Haier HWR10XC3 Air Conditioner
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
Ac blowing hot air , help me , umemployed and broke and hot
check your circuit breaker be careful resetting stand off to the side if tripped the breaker tripped for a reason. you going to need service. i know its not what ya wanted to hear.
Jun 23, 2009 | Weather King 10AJA3601AH Air Conditioner
Ac blowing breaker
The unit will draw more current when hot. Check rating of the breaker against the rating recommended by the manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Dryers Logo
Top Dryers Experts
