Spdif output on my motherboard dont work how can i fix it i install the driver but no sound
  • 34 Answers
You need to change the output to SPDIF in the sound card settings.
Posted on Jul 08, 2008
Sound output through hdmi
DVI is "Digital Video Interface". No Audio is transferred through this type of connection - even if one end of the cable is HDMI.
BEST solution would be to purchase a video card with HDMI output.
Alternate solution would be to run audio from rear audio jack to TV (assuming you have an input on the TV that will accept it)
Dec 29, 2012 | ASUS P5K64 WS Motherboard
I want sb0220 sound card
For Installing & Software purpose you can follow below steps provided by me
1. Removed RAM until I had left 2gb
2. Installed Daniel K driver (vers 1.5 google it)
3. Installed Kx driver (3550-x86 google it)
4. Added the rest of the RAM.
5. Soundcard works good with more the 2GB of RAM on WIN 7 x86
If you have kx driver and you don't get 5.1 sound go to control panel -> sounds -> chose "SPDIF/AC3 Output -> press Set as Default
& u can Download the best software if you have installedhardware from below link too.
Chaeck this out
May this will surely help you a lot.
Jan 05, 2011 | Creative Labs Creative Sound Blaster Live...
No sound from hd graphics card goeforce 2400 output, only picture
Check your audio settings if its set to hdmi output.
Also if that board has a spdif out behind near the usb ports, See if its glowing or on....if not then you have a bad motherboard. Had the same problem before with another asus board
Feb 03, 2010 | ASUS Intel 5000P Chipset...
Lg e500 no spdif output
If you open your sound card properties, you have to tell the hardware (soundcard) to use the SPDIF. For some models of Realtek sound cards, it requires and adapter that you plug into the port and offers optical or coaxial. I could not find anything stating that your PC requires it but I dont have the serial number of your PC to find if you have a different version of the soundcard used in your model notebook.
Also, make sure you are using the proper SPDIF cable to your reciever. This is a digital connection so it requires a 3.5mm to standard male coaxial (RCA) cable. If you are using one, then you just need to make sure that your soundcard knows to ouput audio through the SPDIF port.
Hope that offers some help. If you need further assistance, let me know!
Oct 21, 2009 | LG E500 Express Dual Series Notebook PC
Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Aug 11, 2009 | ASUS Intel 5000P Chipset...
First off, go into BIOS at boot (hold del key) and make sure that your onboard sound is switched on.
Then check your device manager (control panel/device manager) to see if it identifies your sound chip.
Use right click/update driver/search online to see if microsoft can find it for you. If not, it is very likely a Realtek AC97 chip or similar. Search for this driver and go on from there.
Apr 05, 2009 | ASUS P5GDC-V Deluxe (ASP5GDCVDLX)...
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
you may have to set the input on your deck to digital b4 it will recognise the signal
Feb 21, 2009 | Gigabyte Computers & Internet
Receiver compatible with tv
yes digital suround sound is optical spdif k like coxial digital if it dont have analog outs or does it have headphone jack in front run a eth in mini jack to rca offf that to video 1 of sterio ok
Feb 10, 2008 | Televison & Video
ASUS M2N-E SLI sound no longer works?????
Hi Mike,
It is possible when you reinstalled did you install the same version of windows? ie. x86 or 64bit it is possible during the installation process new drivers are updated.
Also, b/c of this fact your motherboard may have spdif out and if it does the drivers installed will be HD audio drivers so check the device manager.
If it is HD audio drivers and using spdif passthrough the only way to hear it is if you send it to a receiver or manual go into the sound module in control pannel and select a different sound source rather than spdif out.
good luck
Jan 07, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
411 people viewed this question
David Payne
David Payne
