Question about Whirlpool Duet GHW9150P Front Load Washer
Wont start and flashed dl then f - Whirlpool Duet GHW9150P Front Load Washer
    Novelist:
  • 99 Answers
HI,
The FdL code is saying the machine lost communication with the door lock. Most often the problem is cold solder joints on the CCU circuit board. The points where the spade connectors and relays are attached to the circuit board did not get enough heat to bond the solder compleatly to the circuit board and component. You'll need to remove the CCU circuit board to repair it. It's located inside at the top of the machine in a plastic case. It's easier to remove the entire case. If you can handle the repair yourself great! if not just print out this response and show it to a good appliance repair shop, they should be able to help you out. Once you have all the joints resoldered that should also take care of an F11 code which often time comes along with the FdL code. Good Luck.
Posted on Dec 31, 2010
What does F DL means i opened the door to add something then t came up F DL and wont start again, the cycle had just started I pressed cancel all it does is beep and flash F DL
Hello and welcome to FixYa
FDL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool GHW9400 Duet Washer
New washer computerized- was loaded and start button pressed is flashing 'dL' and wont begin wash
If its new, never try to repair it yourself. Instead report this to your dealer if you are inside the warranty period.
Aug 20, 2010 | Maytag MAH6700AWW Neptune Front-Load...
GHW94OOPWO....has been solid as a rock for 6 years.....Wont fill up tried to restart and got F flashing then dl flashing steve in sv
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Thank you
Jul 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My 1985 volvo dl turns over but wont start the engine
locate the fuel pump relay sounds like the culprit.
Jan 18, 2010 | 1985 Volvo DL
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont start
the dl code means door lock ,,,, you will need to replace the door latch assy to fix it / larryyb
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
