Question about Brother XL-5700 Mechanical Sewing Machine
The top thread is tight across and the bobbin is keeping loose loops
    Genius:
  • 1,788 Answers
It is in your top threading. Insert new needle (flat side facing rear of machine), totally rethread and make sure that your thread is not old or tangled and of decent quality. Now, with the presser foot up, pull top thread, then put the presser foot down, pull the thread again, it should barely move. This usually seats the thread in the tension discs. If, that does not work, it may be your timing and that is not a do it yourself job, unfortunately.
Posted on Dec 29, 2010
Bobbin tension too loose
You don't give us the make and model of your machine.... so it's hard to give you decent specific advice. Secondly your question isn't making sense. If you are getting loops on the bottom your top tension isn't right(too loose) if your loops are on top your top tension isn't right.(too tight) The only time you would mess with bobbin tension is when you change thread weights significantly. Like from 40 weight to 92 weight or visa versa.
Look at your bobbin case, bobbin carrier, shuttle/carrier..... there is a spring (it's a flat piece of metal) on the spring is a small screw. Use a small screw driver and tighten the spring 1/4 turn. Loosen your top tension a couple turns. (remember right to tight, left to loose)
Mar 19, 2013 | Sewing Machines
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
The tension is off on my machine. The needle thread keeps pulling so tight that it snaps, and the bobbin thread is so loose that I'm getting loops on the backside of whatever I'm sewing. I thought that...
Loops on the backside mean there is no tension on top ,if the top of the sewing l;ooks good then the bobbin tension is correct make sur eyou are threading the top thread correctly
Aug 30, 2008 | Singer 7444 Mechanical Sewing Machine
Brother XL-5700 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
