Question about Delta & Single Handle Shower Faucet
Drips after it is shut off - Delta & Single Handle Shower Faucet
    Sergeant:
  • 182 Answers
The shower valve will continue to leak until the seat and springs are replaced. here is a link that shows you how to make a repair. click on link and then seats and springs replacement.
http://www.deltafaucet.com/videogallery/index.html?filter=howTo#vid-ReplacingSeatsAndSprings
Posted on Dec 29, 2010
Bathroom showers drips
Good news MOEN has a lifetime warranty shut water off to shower then remove the valve behind the knob home Depot or lowes give you new one free with old part
Mar 15, 2015 | Moen Home
Timer has shut off to this valve but water keeps going through valve
Hi Check
There is no dirt in the valve
Normally Shut
Dirt will lift the diaphram
May 07, 2014 | Orbit Irrigation 67790 DripMaster 4-in-1...
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Water dripping from blowpipe
It is normal for water to drip out sometimes from the pressure relief valve outlet pipe. If it drips continuously then open and shut the pressure relief valve several times so the pressure relief valve shuts off properly.
If this does not fix the dripping problem then the pressure relief valve is faulty and needs to be replaced.
Apr 02, 2013 | Water Heaters
I have a split unit that drips water whenever the compressor shuts down.
The unit is probably low on freon....this causes it to build some ice while running. Then when the compressor shuts down it will melt off the coil and drip...
Get the refrigerant charge adjusted properly and you should be okay...
heatman101
May 18, 2011 | Goldstar Heating & Cooling
No water drips from back, after several hours of u...
First. if it's shutting off the microwave, then it's on the same circuit, which is not good. Secondly, as to the drain, check the hose to be sure it is not kinked or obstructed. Is the drip pan and hose seperate from the unit? There should be a small indent on the bottom that allows water to drain, check to see that it is clear. Hope this helps.
May 20, 2010 | Whirlpool ACE244XS Air Conditioner
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Ac wall drips water days after being shut off
Probably get a lot of ice on evaporant,or check drain hose it must be obstruct,clean it.
Decrease temp. on the thermostat.
Jul 04, 2009 | Friedrich CP06C10 Wall/Window Air...
Delta & Single Handle Shower Faucet  Logo
545 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
