Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
The push to start button has to be repressed to make the water to enter the washer. Is this the computer board inside the console?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Yes their is a control card, inside the console. you may have a defective switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Washer won't come on when start button pushed
It sounds like the User control and display board inside the machine is faulty.
Aug 08, 2014 | LG WT5101H Top Load Washer
5600t speed adjust does not work
RUN the software calibration, for troubleshooting and fix it.
See the steps for calibration.
God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
    "F" appeared in). Troubleshooting the failure would be the next step
Jan 09, 2013 | Keys Fitness 5600T Treadmill Drive Motor
The initials FH keeeps comin up on screen when the wash is at 26 minutes Then I have to turn off power and press start button again. What do these initials stand for?
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 12, 2011 | Whirlpool AWM6100 Front Load Washer
MY DELL LAPTOP SOMEYIMES WHEN I PRESS POWER BUTTON IT DOES'NT OPEN THEN I HAV TO REPRESS IT ......i FACE THIS PROBLEM ONLY 2 TIMES IN 1 MONTH......
its probably an issue with the power button, the cables or the board inside. get it checked with a tech.
Apr 23, 2011 | Computers & Internet
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector thoroughly to ensure a good connection.
  • Reinstall the console and reconnect power.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Only one of the wash cycles on my Maytag Neptune TL washer still works. Nothing happens when you press the other buttons. Most of the lights for the additional options are out too (e.g. water temperature -...
Is it a FAV6800AW or FAV9800AW machine? Sounds like it is. I believe you have a Control Board issue; the Control Board has a 5yr warranty. Do you want to DIY a fix or call in a Appliance Repair Tech? Have you reset the 120VAC power on the machine? If not give the Control Board a hard reset by pulling the washer power plug for 10 seconds or so and then re-power up the machine.
I’ll attach the Service Manual link located on this site for reference. See if you can get into Service Mode, try this.
To enter Service Mode, this from the SM.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys simultaneously for three seconds or until the control beeps. The Console display will show “00”.
Access Board Output Test by pressing the Delicates key. The console display will show “ot”
The lid lock will lock and the Quick Wash LED will be lit. Will the machine allow you into Service Mode? If not then it’s time to replace the Control Board. Press the Off button to back out of Service Mode.
Let me know what direction you want to go. Rich
Jul 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not turn on
Did you find a solution? This just happened to me tonight...
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader-will not start
Hello tinagomez479,
Some basic questions for troubleshooting;
Your machine type is a FVA6800AW/FAV9800AW correct?
Any errorcodes to the console?
Can you tell me what this action was for? “”We took it apart and cleaned it and put it back together and it worked good for about 5 loads then the water stopped draining and now it won't start again.”” Was this a Clutch clean up for dc/UC errors?
Does the clicking noise come from the console area like relays clicking or down below where the clutch pulley is located?
When you press the start button do the lid locks lock the lid?
Can you enter into Service Mode? If so can, can you turn on the drain pump for me? This will let us know if the Control Board is at least functioning in Service Mode and will take commands.
Go to page 16 of the Service Manual lower right hand part of page, Board Output Test and turn on the drain pump in service mode and see if the drain pump motor runs.
Here is the process; close the lid and enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00” Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test as the SM states with the off button or hit the Presoak key.
You mentioned it stopped draining, if the Control Board will take the command in Service Mode we can at least get rid of any standing water in the wash tub. When it stopped draining in the wash cycle did you take any error codes to the console like “ND”
Can you also try a Spin Only cycle and see if that will start and complete?
If you can’t do anything at the console pull the 120VAC power plug to the washer for 10 seconds then re-power up and try all above again.
Error codes are very helpful so please let me know what if any error codes you take to the console with your machine issue.
Rich
Jun 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Motor control board frigidaire
E59 No tacho signal for 3 seconds in other words sounds like a bad motor
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
? On non-digital display models, turn the Program Knob to start position, Drain/Spin.
? On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360?, turn the Program Knob to start position, Drain/Spin.
? Press Pause Cancel to turn off LEDs.
? Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.
7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Exiting Diagnostic Mode
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED?s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
? Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
? Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
? Exit Diagnostic Mode to return the washer to normal operation.
Dec 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
