Question about Home
We have a thermostatic shower that runs off a combi boiler in the recent cold spell i believe the pipes have frozen the on control used to only turn about 180 deg but now turns 360 the temperature control only allows hot water and is constantly drawing water from the boiler although this is also intermitent intervals and only runs for about a minute is this an internal problem ie something broken, could the cold water pipe still be frozen it is a triton but do not know the module
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
yes 2 both answer, you pipes can be frozen for days, in the walls, and the control could have failed due to the cold/ice.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
Water fluctuating hot and cold on a shower run off a combi boiler
could be a number issues 1 the hot and cold water supply going to shower could be of unequeal pressure thus the fluctuating 2the heat exchanger in your boiler is conjested with debris 3 the gas bed in boiler is cross burning giving an unbalanced "heat pick up"out put !2 &3 would apply if your on a combi boiler system .if your on a conventinal system you could be pulling air from the head of the cyclinder ,
Jan 19, 2011 | Home
My shower is run off a combi boiler and recently started to go cold for a couple of seconds every few minutes and nobody is running water elsware in the house.
Check the hot water flow at the shower - if it's as good as other taps the boiler diverter valve is suspect. Replace either the complete valve or the internal rubber diaphragm, depending on the boiler make
Mar 29, 2010 | Home
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
