Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Why does my pool cleaner turn upside down? how can i fix it?
  • 640 Answers
Try adjusting your hose weights to see if that corrects the problem. When your cleaner is resting on the bottom of the pool, it should be at 45 degree angle. If it is tilting back toward the hose, try moving the weights closer to the cleaner. If it is tilting forward, try moving the weights away from the cleaner. You might also need to add more hose weight. If the pool cleaner does not have enough weight to hold it down, it will float. You will also want to make sure that you have adequate water flow through the cleaner.
Posted on Apr 13, 2011
Why does my Polaris cleaner turn upside down
check ballast ball round white thing if water inside replace make sure exaust port is at 11 oclock
Apr 22, 2016 | Polaris 180 In Ground Pool Cleaner In...
How can I fix my pool cleaner from flipping upside down during the cleaning process?
Remove weights, Thoroughly clean cleaner, backwash filter system to get optimum suction. Check filter system for optimal suction..., ie. leaks, excess debris, clogged baskets, strainers, etc..
Apr 11, 2016 | Pool & Spa
Why is the zodiac hanging upside down
air trapped in hose or "Hose memory too high" plastic has a memory from its mfg that needs to be relaxed or will cause cleaners to flip over and stay high on walls leave hose straigh out and roll over several times to relax the hose, helps if it's a warm day .
Oct 16, 2014 | Zodiac Pacer Pool Cleaner
How to take apart a legend platinum pool cleaner
take off hose and ball then turn upside down remove 4 screws on 4 corners then top comes off
Jun 28, 2012 | Pentair White/Gray Legend Platinum...
Hello i have a the pool cleaner and it keep turning upside down and then just stays at the bottom upside down and not cleaning. Can you give any suggestions. Thanks
Try adjusting the pool cleaners weights. A properly balanced hose will make the cleaner sit at a 45 degree angle when attached to the pool floor. If the cleaner is rising off the pool floor from the front of the cleaner first, move the weights closer to the cleaner. If the back is rising first, move the weights further back. You might also need to add a hose weight (part #W83247). The only other thing that you can check is your water flow. If you do not have adequate water flow, the cleaner will not perform properly.
Jan 31, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I have a dolphin pool cleaner and it won't sink. Any advice?
If these automatic pool cleaners will not sink, 9 times out of 10 it is because air is caught in the filter bag. The best solution is to turn the Dolphin upside down under water for a few minutes to remove the air or to machine wash the filter bag.
Jun 11, 2010 | Dolphin Maytronics Advantage
Directions on removing filters
Removing the filter on these automatic pool cleaners is easy. It should be in the easy open bottom. After you disconnect, turn the unit upside down and locate and loosen the captive screw. You can clean this area and reapply the captive screw.
May 25, 2010 | Hayward Navigator Pool Cleaner
Phanton pool sweep just turns in a circle upside down
This definitely sounds like an issue with the pool cleaners hose. Look for a bend or kink near the connection between the hose and cleaner. If you notice one, try stretching the hose on a flat surface in the sun for several hours. If this doesnt work, you will probably have to replace the hose.
Apr 24, 2010 | Hayward Phantom Pool Cleaner Complete with...
Flips over
There is a float in the body of the cleaner that keeps it upright. Uour pool store will have this and can change it for you also.
Aug 02, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Dolphin pool cleaner won't go up to top of the pool , only half way up the wall
Most times when a cleaner won't reach the water level in a pool it is usually due to the internal floats being removed or they are no longer in good condition.
Turn the machine upside down, and remove the bag assembly. Should be foam in the plastic housing, underneath, if not replace.
Jul 03, 2009 | Dolphin Maytronics Diagnostic Robot...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
1,866 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
